Question about AT&T Blackberry Curve 8300 Smartphone
How do I turn the "radio" on? - AT&T Blackberry Curve 8300 Smartphone
    Brigadier General:
  • 7,752 Answers
Just try making a call then select radio
Posted on Jan 31, 2010
Instructions for jensen jcr-425 clock radio, how to set clock
To preset a channel on the JCR-425, you tune in the channel; press the "AL/MEM" button on top of the radio (at which time you will probably be switched to some other radio frequency, which is rather disconcerting), press the "Up" or "Down" button to select the desired preset channel number, press "Set" -- and only then are you returned to your desired radio station. If you want to preset several channels,
You might then think that the next time you turn on the radio that all you would have to do is press one of the 10 preset channel buttons on the front of the radio to visit one of your preset radio stations. You would be wrong. You must turn on the radio, then press the "AL/MEM" button on top of the radio. Only then can you access your preset radio stations.
You might also think that to turn on the radio you would press a button that says "Power." Wrong. You press a button that says "Radio." Well, okay. But you might think that to turn it off, you would just press the "Radio" button again. Wrong. If you have pressed the "AL/MEM" button to access your preprogrammed channels, pressing the "Radio" button simply takes you out of the "AL/MEM" function and back to the "FM" (or "AM") function, apparently taking you back to the last radio station you tuned in manually. To turn off the radio after accessing a preset channel, you must press "Radio" twice.
Nov 06, 2016 | Jensen JCR-425 Clock Radio
Please give me link for instructions for jensen JCR-425 clock radio
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Played marine radio for 10 min. radio shut off and wont turn back on this is second radio from yous with same problem radio is plmrkt18
check to see if the radio has a timer in the controls and if so turn the timer off as it is probably turning off the radio for you.
Sep 14, 2013 | Cars & Trucks
Radio aerial will not retract when radio is turned off , but will when I turn ignition is turned off, the last owner has put in a new radio.
The antenna wire has been wired wrongly to receive full time current whenever the vehicle is turned on. It is supposed to be wired to the remote turn-on wire from the radio, so it goes off whenever the radio is turned off.It will have to be rewired to work correctly.
Jul 12, 2011 | Kia Sedona Cars & Trucks
How do i reprogramme the radio on my audi tt please
what you may do is....turn the car off and then turn the radio on.. don't do anything with the car for one hour. meaning leave the radio on for one full hour and the radio itself will reset itself. the radio will turn off.turn the radio on..on the radio it will say... BOSE..press and hold both button RDS and FM2 until the radio resets to 0000 ..then enter in your code..once you enter your code press and hold the two buttons again..this will work...
Jan 19, 2010 | 2002 Audi TT
How do I use a cloning cable to program a hand held MT1000
Cloning Procedure:
(The content of radio A is to be duplicated into radio B)
1. Turn off radio A and turn on radio B.
2. Connect the cloning cable (NKN6376A) to the Universal Connector of both radio A and radio B.
3. Place the PL switch on radio A to the carrier squelch position for full cloning, or the PL position for partial cloning. Full cloning will duplicate the content of radio A to radio B, except for the deviation and squelch settings. Partial cloning is recommended due to deviation variations from radio to radio. (Later version MT1000's (B model for 6, 16, and 99 channel portables; A model for 8 channel) have partial cloning.)
4. Simultaneously depress the PTT and Monitor button on radio A and hold.
5. Turn on radio A. The green LED turns off. Release the PTT and the Monitor button on radio A (HT600's and older MT1000's (A model for 16 and 99 channel portables) beep when cloning is complete). Turn radios "off and on" to reset.
6. Cloning is complete once the green LED turns off. Release both the PTT and Monitor button on radio A. Turn radio A off and on to reset.
NOTE:
For MDC front covers (NTN5456, NTN5457, NTN5458, NTN5459, and NTN6009B), make sure that radio B is turned on before it is connected to the cloning cable.
NOTE:
All VHF wideband radios (146-174MHz) are "C" model radios. A "C" model radio can be cloned only to/from another "C" model radio. An attempt to clone a "C" model radio to an "A" or "B" model radio will result in an unsuccessful cloning attempt.
Any unsuccessful cloning attempt (depending on operating condition of the radio) will result in one of the following alerts:
1. in receive (rotary radio) - 1600Hz continuous alert tone
2. in receive (display radios) - 88 displayed on LCD
3. in transmit - 1600Hz beeping alert tone
Nov 04, 2009 | Motorola For MT1000 MTX800 MTX90010v...
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
02 VW GTI Radio says CHECK
This worked for me (radio in 2003 VW Golf):
Radio says "CHECK" but is otherwise unresponsive. Turning car or radio on/off doesn't help.
On the far right of the radio, there's a round TUNER button. Press it for 5 seconds. Your screen will then show some digits, but the unit is still unresponsive.
Press tuner button again for 5 seconds. Radio should now be 100% again. Let me know if this works for you.
Nov 21, 2008 | 2002 Volkswagen GTI
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
