Question about Whirlpool Dishwashers
How do you replace a flow meter on a whirlpool dishwasher
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
Dishwasher not washing or drying dishes properly
F7 - Flow meter failure
Water inlet valve (WVI) is switched on and water indicator (WI) is on (full).
  • Flow meter (FM) sends too few impulses (less than 10 imp. in 10 sec.).
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective
  • Flow meter (FM) defective
To erase the failures, you must push the start button longer than 1,5 seconds.
Dado
May 11, 2015 | Whirlpool 24 in. ADP5966 Free-standing...
What does the F7 code mean for my whirlpool dishwasher ADG6230
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
  • Water inlet valve (WV1) defective (mesure resistor ca 3,5 kOhm)
  • Flow meter (FM) sends too few / much pulses (less than 10 imp. in 10 seconds). Flow meter counts wrong (or the sump is full in less than 30 second).
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
  • Aquastop defective
Dado
Feb 17, 2015 | Whirlpool Dishwashers
Free whirlpool repair manual
Hello, Without a model number, I can be of limited help. But the F07 fault on a whirlpool dishwasher is indicating a problem with the water intake flow meter. Check the connections at the meter, if good replace the flow meter.
Unplug the appliance.
Take it out of it's installed location
Remove the left side panel .
In the large plastic tank on the left side of the machine is the flow meter. It will have a 2 wire plug on it.
Pull the plug off and push it on again a couple times.
Make sure the connection is dry and tight.
Try the dishwasher.
If you receive the F07 fault again, replace the flow meter.
Apr 21, 2014 | Dishwashers
F7 is showing and every tme we reset it starts off then returns to F7
Generally depending on the brand the F7 error code is a FLOW METER problem. Is your dishwasherone of these brands
whirlpool
kenmore
kitchenaid
roper
estate
kirkland (costco)
is it from IKEA
If it is a whirlpool brand its very likely the flow meter that is the problem. This is what the flow meter looks like if it is one of the above brands
it is on the left side wall inside the tub and its where the water enters the tub, to replace it ya need to pull the dishwasher out of the cabinet
GENE
Aug 27, 2011 | Dishwashers
What does erroe f7 mean?
Hi
This error indicates a fault with the water flow meter. F7 means inlet flow meter malfunction
Remove the left panel and check the flow meter, try to unplug it and plug it again.
If not OK, change the part, If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. Then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Whirlpool Dishwashers
Code f7 appearing on whirlpool dishwasher adp 6940/5
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck, Appliance Specialists
Dec 08, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Washer starts to fill then stops after a few seconds?
this sounds like a flow meter problem, replace the regen unit on the machine- this should solve your problem
Jun 12, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool adg 7550 starts cycle then beeps and flashes 6 times whats wrong?
6 flashes indicates water intake fault ie machine is saying it has not filled with water within the required time.
-Check inlet hose not kinked or blocked.
-Next, check inlet valve is OK (check with ohm meter-should read approx 4k ohms). If no circuit thru valve, replace.
-Could also be fault with water indicator switch (much harder to access and diagnose- located underneath sump on right hand side).
-I have also had this occur because of a faulty flow meter. Flow meter measures the volume of water as machine fills. Flow meter is large plastic chamber located on left hand side of machine (accessed by removing left hand side panel). It has a sensor on the bottom with 2 blue wires. Unfortunately again, very hard to test this component without specialist equipment.
Hope this is some help- not sure how technically minded you are, but checking inlet hose for kink/obstruction is a good place to start, then advise calling service technician unless you are a confident DIYer
Aug 10, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
Nov 24, 2008 | Whirlpool Dishwashers
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
