Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
What size of system fan is in HP pavilion media center m8400f PC
    Master:
  • 576 Answers
2 Suggested Answers
  • 1011 Answers
SOURCE: Can I install pci-e X 16 2.1 video card onto my HP Pavilion Media Center m8400f PC
Its a slot distribution both 2.0 and 2.1. 2.1 is a bit faster as it leads with version. You can install any VGA card that supports it but keep it in your mind that more heavy vga card will require more power. So, you power supply should be heavy and should bear more power for your card as well as your system.
Sometimes, it require to change the power supply as well.
best of luck!
Posted on Mar 18, 2012
Low level format
First you can use this tool: http://hddguru.com/software/HDD-LLF-Low-Level-Format-Tool/,
Now if there is only one disk in your PC you need to mount the drive in another PC where the "tool" is installed.
In the same PC you can use a "live bootable linux cd [like ubuntu]" that includes these kind of tools.
Aug 08, 2014 | HP Pavilion Media Center TV M8400f Pc PC...
Wireless router
well the only place you can check is if you right click on your my computers on the desktop, click on properties, go to device maniger and there you will see all the hardware in the pc.
Oct 24, 2013 | HP Pavilion Media Center TV M8400f Pc PC...
Hp m8400f power up problem
Power Supply problem Bob.
Weak voltage power rail.
Allow me to explain what is going on;
1) Monitor is working OK. Shows No Signal.
Means No Video signal is getting to the monitor. This is because the computer isn't working.
Monitor goes to Sleep Mode, or Power Saver Mode, to conserve power.
2) Orange LED comes on, and fans spin.
Means NOTHING.
Light Emitting Diode, so it is a LIGHT.
A) If ALL the LED's were on at once, they would use LESS than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical CPU (Processor) uses 51 to 125 Watts of power.
Hmmm, HP Pavilion M8400f Desktop PC?
http://h10025.www1.hp.com/ewfrf/wc/product?product=3686665&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374051&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3686665
(Showed you the path)
Hardware / Base Processor;
AMD Phenom-9500 (A) 2.2 GHz (95W)
Uses Up To 95 Watts of power.
This is why the simpy LED's light, and fans spin; BUT there is NOT enough power to turn the Processor (CPU) on.
Method to repair is up to you Bob, but I would recommend testing the 3 main voltages coming out of the Power Supply, with a multimeter; OR using a KNOWN to be good, Compatible power supply for a temporary test unit.
Or you can buy a replacement Power Supply.
I would just like you to test the Power Supply, or use a temporary replacement, so you do not rush out, and buy a Power Supply; and find this wasn't the problem.
A economical multimeter, (But is plenty good enough for this test), can be purchased for as little as $5 to $12.
An auto parts store is bit one example. (Although usually a little more pricey)
I have seen them on checkout aisle racks, at major discount stores.
The dangerous (100 to 240 Volts AC. Depends on what country you are in), voltages are KEPT within the metal case of the Power Supply.
The voltages coming out are 3.3 Volts, 5 Volts, and 12 Volts.
All are DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC.
Replacement Power Supply?
Try the easy method.
Type - Pavilion m8400f power supply in your search bar, and press the Enter key,
From one search hit,
http://www.sparepartswarehouse.com/HP,Media-Center,m8400f,KJ377AA,Computer,Power-Supply.aspx
To the right of View Details states 5188-2625
That is the HP part number
HP 5188-2625
Search HP 5188-2625,
http://www.amazon.com/s?ie=UTF8&keywords=hp%205188-2625&page=1&rh=i%3Aaps%2Ck%3Ahp%205188-2625
This particular search hit has various examples shown.
ALL examples are ATX.
ATX is a Form Factor,
http://en.wikipedia.org/wiki/Computer_form_factor
Originally designated for Motherboards. (Mainboard)
Went to Power Supply's, and computer cases, also.
An ATX form factor for a Power Supply, designates it's size, and shape; plus the types of power cables coming from it.
(Also the inherent technology)
Size and Shape:
Approximately 6 Inches Wide, 5.5 Inches Long, and 3-1/2 Inches in Height.
(152.39mm Wide x 139.7mm Long x 88.89mm in Height)
If you buy an ATX power supply nowadays, it will have the correct power cables you'll need, and probably ones you do not need, plus more than you need.
Works out pretty good, huh? Just wrap the power cables you do not need, with PLASTIC tie strips, and up out of the way.
(DON'T use bread ties. They have a metal strip in the middle)
The original Power Supply is reputed to put out a Maximum rated Wattage of 300 Watts.
KNOW THIS,
A computer ONLY uses the power it needs, and NO MORE.
If you put a 10,000 Watt Power Supply in, and the computer only needs 100 Watts for what it is doing, it ONLY uses 100 Watts.
You should use a Power Supply, that is rated at least 10 percent more than what is needed.
One example of a replacement Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276575&CatId=1078
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583783&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3686665
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01358091&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3686665
I can step by step guide you in testing the voltages, with a multimeter; and also in replacing your Power Supply.
Post back in a Comment.
Regards,
joecoolvette
Feb 16, 2013 | HP Pavilion Media Center TV M8400f Pc PC...
best of luck!
Mar 17, 2012 | HP Pavilion Media Center TV M8400f Pc PC...
I need instructions on how to unhhok the old power supply and install a different one.
You can get a power supply here (and other places).
http://www.power-on.com/atx12vhp300bt.html
You can get one at 300, 350, 460, and 550 watts. This is just one site, the power supply can be found at other sites.
Here are sites that have instructions on replacing a ATX power supply.
http://www.fonerbooks.com/r_power.htm
http://tech.blorge.com/Structure:%20/2009/01/03/how-to-replace-a-desktop-pc-power-supply-unit-psu-tutorial-with-pictures/
Apr 14, 2011 | HP Pavilion Media Center TV M8400f Pc PC...
New hard drive which I'm trying to install in HP M8400f I have taken off the side panel but how does the new hard drive install?
There will be a 3.5" bay with screws holes that the hard drive will go into. (Usually two metal columns in the front of the machine)
First, Make sure the computer is turned off. There is potential for harm to yourself and the machine if you leave it on.
Place the drive in the bay and screw it in. Connect the large sata cable for the power connect the small sata cable for the data
make sure the data cable is also connected to the motherboard
Put the side panel back on and boot up the machine. You will probably need to format the drive in order to use it.
Mar 08, 2011 | HP Pavilion Media Center TV M8400f Pc PC...
NO SOUND
just what the doctor ordered - peace and quite
May 17, 2010 | HP Pavilion Media Center TV M8400f Pc PC...
Computers & Internet Logo
85 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
