Question about AMD Computers & Internet
Maximum Ram can the Elite K755A Motherboard take?
I want to upgrade the amount of Ram to 1 gigabyte from the current 512 MB. I want to replace the 2 x 256 MB with 2 x 512 MB.
    Problem Solver:
  • 18 Answers
The specifics for that motherboard can be found at the ECS website below which will detail the hardware limits for your motherboard.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=420&CategoryID=1&MenuID=22&LanID=0
Posted on Jan 09, 2015
ldnleaf
  • 7 Answers
SOURCE: upgradation to 1 gb ram
Go to this site http://www.crucial.com/ and follow the instructions and it will give you the ram that is compatible for your system.
Without knowing the manufacturer
and model it is difficult to give you the info. Use the site above and it will be specific.
Posted on Apr 25, 2008
SOURCE: UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Posted on Aug 24, 2008
SOURCE: Gigabyte Model GA-7DXR Motherboard
hi i have aGA-7DXR motherboard iin a comp o use for the grandchildren. it has ben working ok, but on moving it , it it now powerless. i believe this is because the power sw connection has come off the motherboard. can anybody tell me where to plug it onto the motherboard.
regards
john peatman
Posted on Aug 28, 2008
roety
  • 585 Answers
SOURCE: my system is AMD Athlon(tm) XP 2000+.I want to
your motherboard can support up to 2GB of DDR ,
here is the manual for download linked
The hard drive is not limited as far as the motherboard is concerned, but you would need to use windows XP with service pack 2 or higher to recognize over 130 gigs when installing.
hope this answers all your questions
please click accept and thanks you for using Fixya
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 30, 2009
SOURCE: Hello again.I have an old home pc and I want to
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Posted on Apr 30, 2010
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
I want to increase the memory ram for my HP Pavillion a 335 w , on my research so far I found that the largest memory it takes is the 512, it already has 1 gyga, in it, so I assume it has 2 512, I would...
the maximum amount of RAM for that pc is 1GB so upgrading isn't possible if you wanted to upgrade the speed of the RAM the maximum speed is 333 MHz which is not very fast so i would assume that's what the current RAMs speed is.
Apr 01, 2011 | Computers & Internet
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot...
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Feb 07, 2010 | Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Computers & Internet Logo
115 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
