Question about Kenmore Dryers
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
My Kenmore series 70 won't heat. I have a meter to go in and check to see what the actual problem is. I watched a video on how to check all of the heating element stuff but it was on a series 90. How do I access the parts since my front of the dryer does not have that bottom part you can remove to get to the heat elements?
Posted on Jun 26, 2009
  • 351 Answers
The part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Posted on Jun 23, 2009
4 Suggested Answers
  • 36 Answers
SOURCE: Kenmore 70 series dryer works but no heat
check your power if one leg is down eg 110 to the motor drier will run but not heat if the heater is getting 110 but not the motor drier will do nothing check for a partial tripped breaker eg one side tripped but not fully just turn off and reset check outlet for 220 check power cord at terminal block for loose or burned cord unplug first lol if cord is burned just means it was loose when in stalled most of the time this promb is elec.
Posted on Dec 29, 2007
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer doesn't heat
The problem may not be the heating element. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All Kenmore dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Aug 10, 2009
My kenmore 70 Series dryer model 110.96573220 runs but does not heat. The heating element ohms out at 9.8 ohms, thermal fuse and high limit have continuity. I have 240v at the terminal bar.
you should have continuity at on the element as well. if there is a resistance value thats a bad thing
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Kenmore Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
420 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
