Question about Microwave Ovens
Will not process all the water installed........machine is level machine isn't even a year old and problem started three weeks after purchase
    Genius:
  • 1,847 Answers
If it is not at all heating then the magnetron need to be replaced.
When replacing the magnetron, it's very important to be sure the new one has the wire mesh "washer" (RF gasket) around the antenna which sticks out the top. If it's not on the new one, use the one from the old mag. Very important.
Also, you should really discharge the high voltage capacitor
Thanks
Kevin
Posted on Jun 23, 2009
Bought a new white ice whirlpool microwave and the auto vent won't turn on automatically no matter how hot or how long we cook food....we can turn it on manually. The authorized service man replaced...
This should be a warranty replacement if you can get Whirlpool to respond. Try returning the microwave to the point of purchase for replacement
Aug 04, 2013 | Microwave Ovens
Sn797s panasonic microwave change light bulb
Probably located inside the cabinet which will have to be removed. Be aware of dangerous, even exposed voltage present with cabinet removed.
Dec 29, 2017 | LG LRMM1430 Microwave Oven
Pop out dial does not go back in in my panasonic microwave oven
Take it back to the place of purchase and let them deal with it, may have a manufacture glitch.
Apr 10, 2012 | Panasonic NNSD967S Stainless Steel 1250...
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
Machine goes through the motions but water comes out cold
Hi,you have not stated how old this unit is ? I think they are supposed to last for 4-5 years but I've known some to break after just one year and others that worked great for 15 years or more.
Read more: What is the average life span (during normal use) of a microwave oven? ' Answerbag http://www.answerbag.com/q_view/1540053#ixzz1TQlW7RlH
Carbon Heating Lamp for microwave oven strong heat resistance. More than 6000hrs lifespan.
From a website...
7.3.7 Magnetron Life Expectancy
The typical life of a magnetron tube is approximately 2000 hours of operation. Some factors that can diminish the life of a magnetron are: 1) no-load operation, 2) operating with too much metal in the cooking cavity, 3) line voltage consistently too low or too high, 4) improper phasing, 5) improper installation or removal, 6) replacing associated high-voltage components with substitutes that are incompatible with the system design, 6) continual operation at the upper limit of its heat tolerance due to inadequate air circulation, 7) obstruction in the wave-guide, 8) failed stirrer operation.
We use ours about 15 mins a day which would mean 2000 hours would be reached in 22 years but as they say there are a lot of factors which may reduce its life. The design and parameters of the oven will make a considerable difference. E.G. A highish power magnetron always underrun will last much longer than a smaller one run at its max ratings.
A restaurant might reach 2000 hours in only a year or so and industrial machines whether for cooking food or other processes will require frequent magnetron replacement.
http://www.alibaba.com/product-gs/439406670/Carbon_Heating_Lamp_for_microwave_oven.html
Jul 28, 2011 | AEG Microwave Ovens
GE Profile Spacemaker XL JMV1460 Turns On by Itself
Sounds like there is a stray piece of wire or other metal floating around inside the case. Remove the cover and any breakables in the microwave (the power cord is unplugged for this), turn it upside down over a table and shake it, pound the bottom, and shake it some more--likely the offending piece will drop out onto the table. If so, put it back together and whack it to see if that fixed the problem (cord plugged back in). This process can be repeated.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GFCI Trips After an Hour
It is possible that the extention cord is the problem. Over time wires will heat voltage will drop. Along with the added distance on the code the voltage drop cause a drain and trips the GFCI. Try replacing GFCI and also try opperating without the extension cord.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jun 12, 2009 | Panasonic NN-H764 Microwave Oven
GE Monogram Microwave
GE, couldn't even find the model number. They pretty much, in a nice way, told me I was out of luck, it would be $149. for them to tell me why it's not heating. If it's the magnatron tube, they'll cover the PART ONLY!!
I took in to ABT, where it was purchased, it's now, three days later, they still haven't called to let me know what the problem is and how much it will cost to repair.
I purchased a Panasonic oven for $79. and am making do for now.
Thanks.
Nov 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Troubleshooting my Kenmore 721.66227
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, when you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting Sears to get it fixed free.
Aug 21, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave turns off after 1-2 seconds
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
May 29, 2008 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
