Question about Savoy House Dryers
Monarch ceiling fan owners manual
Savoy House Monarch Fan -- The four wires at the top are Black/White Orange and Blue. What does the Blue and Orange wire connect to.
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 25 Answers
SOURCE: New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Posted on Jan 18, 2009
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
Where can I get a copy of the savoy 68-CF-5HK-SN instruction/owner's manual.
Hi ldw5000...
I am sorry I could not find a manual for your fan, but I did find a phone number of the people that sell it and they can answer any questions you have...they may also be able to furnish you with a user manual for your fan.
Please take time to rate me
Here is the website
http://www.littmanbros.com/savoy-house-monterey-68-CF-5HK-SN-ceiling-fans.html?utm_source=Shopping_com&utm_medium=CSE&utm_content=product-savoy-house-monterey-68-CF-5HK-SN-ceiling-fans&zmam=15972151&zmas=2&zmac=45&zmap=savoy-house-monterey-68-CF-5HK-SN-ceiling-fans
Here is the phone number
Have questions or need advice? Call 877-237-9098 to speak with a lighting professional
Aug 17, 2011 | Savoy House Dryers
I have four wires from the ceiling fan black white blue orange just 3 wires from the ceiling box white black and ground how do I wire it?
Try hooking up without the oprange , connect the white to white ,.. and the house black to the fan black and blue. The ground will connect to any green or bare wire, and also to the fan mounting bracket
May 18, 2010 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My fan has three wires, black white and blue. It had no manual and I wonder how to wire it to the on/off switch.
Put the black and blue wire together with the black wire on ceiling. Put the White with the White wire on ceiling. Bare/green wires are ground put them together.
What fan wires do.
The black wire is to power the fan motor.
The blue wire is to power the light on fan.
The white wire is neutral.
If you wire this way you turn on the switch and use the pull chains to control the fan and light.
You can also buy a remote control unit at a home depot. And it will have instructions on how to hook to fan and ceiling.
Jan 02, 2010 | Hampton Bay 52 In.Carriage House II in...
Can this fan be installed without the light kit? If so, will the upper light work?
most newer ceiling fans have 3 wires, a black, white and blue. The blue is for a light kit which is optional in most cases. All other functions should work.
Dec 11, 2009 | Hampton Bay AC434-NI Ceiling Fan
Ceiling Fan
Green is always equiptment ground. It goes to the green wire ,if you have one in the electric outlet box,or mounted to the box itself itf you have not the green in the box.
Green always  to green White to white. Nutural wire. Orange to black if their is no black in the box. Orange =Black
I am also thinking that you blue will is also the positive for the fan. I woudl hook it to your orange also .  .
Jan 05, 2009 | Hampton Bay 24002 Ceiling Fan
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
Top Savoy House Dryers Experts
Dan Webster
Dan Webster
Are you a Savoy House Dryer Expert? Answer questions, earn points and help others
