Question about Stanton SMX202 DJ Mixer
Stanton mixer channel fader broken - Stanton SMX202 DJ Mixer
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
on Aug 07, 2008 | Yamaha Mg102c Stereo Mixer
How to use a mixer board
Input at each channel XLR or 1/4 ", at faders(bottom) are assignment buttons for sub groups or to stereo out put and main faders drive audio to amps.
Feb 27, 2011 | Behringer Sx2442fx Eurodesk 24channel...
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
Faders not working properly on am844d right channell goes in out when I wiggle the main L/R fader. Some of the channel faders are eractic. The level of volume is not responding right to fader...
You probably wrecked the faders putting De-Oit in them!!! NEVER use that in pot and faders... It is for switch contacts only.
You have ONE chance to save them. From Home Depot get a can of CRC226 in the electrical dept. Put some of that using the spout into each fader near the middle and work the faders. The CRC226 costs about $2.70 a can. Make sure it is the 226 as there are OTHER CRC products there and only 226 is the one that is suitable.
The De-Oxit will have cleaned out the lube of the faders and if you are unlucky, one or more of the wipers will have folded back which is fatal... The CRC226 is an electrical lube that I have restored faders and pots with... It has many other uses including lubing plier joints...
Dec 31, 2010 | Phonic Am 844d Mixer 8 Mic/line 4 Stereo 4...
What is the value of mackie's faiders and master faders
The channel faders will be a 10K with standard fader taper.
The master fader is a 50K dual, with standard fader taper.
Sep 20, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Stanton SMX202 DJ Mixer Logo
14 people viewed this question
Top Stanton Music Experts
Vito Vacirca Jr.
Are you a Stanton Music Expert? Answer questions, earn points and help others
