Question about Acer Aspire One PC Notebook
Cant open network center, cant connect to wireless
Did live update, network center icon disappeared from the bottom right hand of screen in toolbar. cant click on the network center and it wont open!
having to use mobile internet dongle
  • 98 Answers
Do a restore to a previously good state.........
Posted on Jun 23, 2009
No wireless connection suddenly. internet only works by cable in laptop and home hub
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 15, 2013 | Toshiba Satellite Computers & Internet
Tip
How to Boost Wireless Adapter Signals
Right-click the "Network" icon in the Windows Notification Area at the bottom right of your desktop, then click the "Open Network and Sharing Center"option from the menu.Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option.Click the "Configure" button, then click the "Advanced" tab.Click the "Channel 802.11n/b/g" option from the menu, then type a new value between 1 and 11. Click the "OK" button to save the changes and close the dialog box. Update Wireless Adapter Driver Right-click the "Network" icon in the Windows Notification Area, then click the"Open Network and Sharing Center" option from the menu. Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option. Click the "Configure" button, then click the "Driver" tab.Click the "Update Driver" button, then click the "Search automatically for updated driver software" option. Windows automatically searches for and installs the latest driver for your wireless adapter.< Click the "OK" button on both dialog boxes to save the changes and close the window.Update Router's Firmware <li>Click the "Start" button, then click the "Computer" l Click the "Network" heading from the left pane, then double-click the"Internet Gateway Device" icon under the Other Devices section. Your default browser launches to the login page of the wireless router. Type the username and password, then click the "OK" button to log in. Click the "System" icon and then click the "Update" option. Click the "Yes"button when the wireless router configuration tool asks if you wish to search for the latest firmware on the Internet.out of the router's configuration utility boost-wireless-adapter-signals.
on Nov 02, 2010 | Tivo Wireless-G USB Network Adapter
No wireless download
Jan 15, 2013 | Computers & Internet
My wireless network connections r missing
click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Dec 17, 2012 | LG X-Note LM50 Notebook
How to switch on wireless
Dec 10, 2012 | Computers & Internet
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Its not connected wirelessly and i cant get on wirelessly
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 23, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cant connect laptop via router
Dec 05, 2009 | Computers & Internet
Please help me get my wireless settings
If you have windows XP on the laptop then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista on the laptop:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa
rating. If you cannot rate this post with the highest rating, then please
comment to this post and I will try to help you further.
Regards
Anand
Aug 30, 2009 | Acer Aspire 3000 Notebook
IT DOESNT WORK OUT
Sounds like your wireless is disabled.
If your using windows xp, check the following.
Go to your start menu
go to your control panel (might be under settings, might not.)
from control panel, if it says "Choose a Category" click switch to classic view.
open your Network Connections Icon.
If "Wireless Network Connection" is grayed out, right click it and choose, "Enable."
In Windows Vista
Go to the bottom right hand corner of your screen to the icons.
Right click on the double monitors (network connection)
Select Network and Sharing Center
Click on Open Network Connections
If "Wireless Network Connections:" is grayed out, right click it and choose, "Enable."
If it is enabled, and you already have wireless built in to your laptop, then it's possible the wrong wireless card is enabled. If this is the case, when you open your network connections, you will have two Wireless Network Connection Icons.
A Wireless Network Connection, and a Wireless Network Connection 2. Make sure 2 is enabled, and the first one without a number is disabled.
Let me know if this helps.
Mar 17, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Acer Aspire One  PC Notebook Logo
342 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
