Question about Cell Phones
How to unlock sun mga 1200 exhaust gas analyser
2 Suggested Answers
SOURCE: my sun analyser is locked
Hi, I am sorry to have to tell you, but once that "lock" has been activated it cannot be "Un-done' as it were without, "Programming". you see, when "Calibrated' well, after it is done, the microprocessor, is updated with the NEW calibration data, now without that data it will not "reset" it is just that simple.
Posted on May 06, 2011
I need service manual for my SUN MGA 1200.
It would appear the only surviving copy of the Sun MGA 1200 is a scanned PDF in Swedish. I logged into Sun's archives and noticed the majority of their archives are in Swedish. I've attached a link so you can download it. The PDF can be translated through various free online sites; I recommend Google Translater http://lifehacker.com/5166588/translate-entire-documents-and-pdf-files-with-google.
One account All of Google
Jun 13, 2014 | Cell Phones
Engine light flashing
Normally when you experience this problem this indicates that you have an engine malfuntion. your engine will not want to accelerate and give you unstable accelaration like jerking every so often.
I had this problem before with my Chysler van and I located the problem to the Exhaust Gaz Recycling unit located on the exhaust manifold. This unit allows the unburned gas of the exhaut to be burned again. It is a valve that is activated by the oxigen sensor.
I took the defective EGR apart and found that the diode connected across the activating coil that operates the valve to be defective. It is an expensive part for some to replace but do not attempt to replace it by a used one...otherwise your problem will reoccur. A good car dealer should be able to analyse your problem by checking your engine with his analyser/trouble shooter.
Feb 13, 2014 | Chrysler 2002 Concorde LX
The obd2 is not working and I'm trying to get my inspection done
connecting to the OBDII is not part of the test ,the emmisions are tested by putting a probe up the exhaust pipe and running engine at 2500rpm then the CO and lamba are checked on a gas analyser .
Jan 03, 2013 | Cars & Trucks
Bajaj ct100 exhaust noise
Hi, Anonymous para sa sitwasyong ito Gusto kong tumawag sa aking mga lokal na dealer o serbisyo / department bahagi kagalang-galang na tindahan at magtanong tungkol sa anumang mga posibleng mabilis na ayusin , mga sagot, o pagtatanong bahagi. Kung kinakailangan transport iyong sasakyan sa dealer o tindahan at magkaroon ng isang propesyonal na tekniko dalhin ito para sa isang test drive, kung ito ay nasa tumatakbo kondisyon, at magbibigay sa iyo ng isang nakasulat na pagtatantya ng pag-aayos at sagutin ang anumang mga tiyak na katanungan na maaaring mayroon ka tungkol sa iyong isyu . Para sa karagdagang impormasyon tungkol sa iyong isyu mangyaring bisitahin ang website sa ibaba. Good luck at magkaroon ng isang magandang araw. Bajaj Pulsar RS200 Exhaust Sound Twin Projector LED Indicators Crystal LED...
Modenas CT100 Exhaust Sound Test By Khairil
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Jul 11, 2012 | 2006 Bajaj CT 100
Di ko mabuksan ung phone ko ng ibang sim card na try ko na lahat ng code di parin gumagana,,
Ba ang iyong mobile ay may SIM lock o kandado ng Telepono? kung ang SIM lock nito na maaari mong i-unlock ito sa pamamagitan ng code ng unlock at para sa mga code maaari mong kontakin ang iyong kasalukuyang provider o maaaring makakuha ng ito mula sa mga online provider at kung ang iyong mobile ay may telepono lock pagkatapos ay maaari mong i-reset ang iyong mobile sa pamamagitan ng mga code ng master reset .. kung i unlocking4u na pagbibigay ng parehong unlock code at master reset code para sa maraming mga mobile na mga modelo .. suriin muna kung ang iyong mobile na modelo ay nakalista at pagkatapos ay tingnan kung aling mga code ang iyong nais, kumuha ng mga ito at makakuha ng iyong mobile-unlock ligtas ... at kung mayroon kang anumang mga pangunahing modelo mobile unlock agad mula sa unlocking4free pamamagitan ng unlock code ...
Aug 08, 2011 | Nokia Classic 2700 Cell Phone
I need a workshop manual for a mitsubishi L300 van 1990 model need to find mixer screw please
The mixture screw is located in a resessed hole just above the therma start plate at the rear of the carby. The rear of the carby faces away from the inlet manifold and you require a special tool to access this adjustment. The other screw adjustments on the carby and linkages are for idle, fast idle, and choke limits including those models with automatic (thermal type) choke mechanisms.
I would advise that if you make any adjustments to the mixture that you have the mixture checked using an exhaust gas analyser.However, as a general rule of thumb, screw the mixture adjustment all the way in until you feel it tighten but DO NOT FORCE IT !! the screw has a delicate needle valve on the end which will be damaged if the screw is forced beyond it's normal length of travel.
Unscrew the mixture screw a total of one and a quarter turns back out and then have the setting checked with a exhaust gas analyser. Too rich and not only is this expensive but will cause damage to spark plugs etc. Too lean a setting will cause a misfire which will damage valves and pistons.
Mar 08, 2011 | Mitsubishi Passenger Cars & Trucks
1998 Sportster XLH 1200 seems too smoky. Carb, including jets were checked - ok. Not visible smoke, but just gives rider that exhaust smell even after short trips. 14 k miles and recently serviced. Is this...
Is this a recent development? Or has it always left that smell? I had an older Sporty, that I ran too rich for years, it left lots of black soot on the inside of the exhaust tips, and a very pungent exhaust smell on your person. When I went down a couple jet sizes, it got much nicer, and ran a little better as well.
Jul 27, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
1998 Jagual XJ8L Van Den Plas
Mine the same, done timing chains and tensioners, gas analyser shows it to be running rich on one bank only, swapped injectors with other bank and changed all 'o' rings. Isn't running rich when revs above 1500 so think it may be VVT on one cam, removed solenoids and found shuttle valve sticking in on one side, shuttle springs back out on other bank, going to replace in near future, maybe you have same problem, get exhaust gasses analysed to find if one bank running rich when idling.
Jun 28, 2008 | 1998 Jaguar XJ8L
Cell Phones Logo
663 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
