Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
WFMC6400 when drum spins it sounds like the bearings need grease
My WFMC6400 was in a basement flood. The machine was standing in 8" of water. The machine dried out for 10 days before trying it. It starts OK and seems to wash and rinse like it should, but when the drum spins it sounds like the bearings need grease. The faster it spins the louder it gets. If you spin the drum by hand it makes the same sound.
    Problem Solver:
  • 18 Answers
The motor bearings are damaged. You need to replace the motor
Posted on Jun 23, 2009
During spin cycle drum makes loud noise. Sounds like bearings are going out. Can they be lubricated? Or replaced
Depends on what sort of machine it is. (Front or top load)Bearings can be replaced but this will always entail replacement of all the tub seals and in the case of front loaders, almost always , it will need a new drum shaft. The costs to fix can be expensive. To confirm bearing failure, you can see if the tub moves and clunks on the main shaft and the noise will increase as the tub speed increases. Drum bearings usually fail when the tub seal fails or is worn out, allowing water to get into the bearing and wash all the grease out. Brown , black greasy stains under your machine and on the floor is usually a telltale sign as well.
Mar 20, 2017 | Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Washing has marks on it, look like grease or rust. Have tried all the appliance cleaners on the market and still doing it. Much worse on heavy wash and fast spin.
I'm sorry to say that this is potentially very bad news. The problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about". Grease from the bearing and rust that has formed as a result of water tight seals for the bearing breaking down causing the bearing components to rust is probably what you are seeing on your washing.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Aug 03, 2011 | Zanussi FLE1416W Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Washer is making a lot of noise when spinning out and it is leaking water at that time.
this is a common fault and is a sign that there bearings on the machine have failed water is passing passed the bearing seal through the bearing , rusting the bearing on the way (that what cause the noise as the grease either leaks out or is washed away) there is now no lubricant it will in the end shatter the bearing or the bearing will collapse and the drum will spin wild and could damage other parts of the machine recomend replacing drum bearings soon as possible PS: the bearings are most likley to colapse when the machine is under most load IE a fast spin
Jan 16, 2010 | Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    LG Washer makes LOUD noise when spinning
    The main seal is leaking on the drum bearing hence the splatter of soap softened grease The water from the drum is coming through the seal and into the bearing and this is washing the bearing clean of grease. No option than to get it replaced with a new drum bearing kit , Sorry !!
    Jun 04, 2009 | LG Washing Machines
    Two problems, mildew smell and loud noise in spin cycle
    drum bearing failure due to the water seal in front of the bearings failing the smell is probably the grease mixed with water in the outer tub
    Jul 15, 2008 | Frigidaire GLTF1240A Front Load Washer
    Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
    251 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
