Question about Fisher Paykel Dryers
WHY CLOTHES ARE STILL DAMP AFTER COMPLETE DRYING CYCLE IN FISHER PAYKEL INTUITIVE DRYER?
    Sergeant:
  • Fisher Paykel Expert
  • 467 Answers
Either faulty sensor or blocked filter
Posted on Oct 26, 2017
reg501
  • 413 Answers
SOURCE: Kenmore Elite quiet pak 9 dryer
Error message E1 indicates the temperature thermistor has failed.
Posted on Jun 22, 2008
  • 4 Answers
SOURCE: DLE5955 Tromm Dryer. We have had
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Posted on Jun 26, 2008
  • 198 Answers
SOURCE: clothes still damp after running a cycle on auto moisture setting
Clean the vent hose and vent outlet
Posted on Dec 04, 2008
localwonder
  • 6784 Answers
SOURCE: Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Posted on Sep 05, 2009
smartr10U
  • 1305 Answers
SOURCE: AEG 59800 dryer is not drying, it runs the full
If the clothes going in don't appear wetter than normal, then it's probably lack of airflow.
Check your dryer venting.. especially directly behind the machine. Pull the machine out and disconnect the 4" duct from the back of the machine and visually check for blockage both in the machine and in the duct work. Use a vacuum hose to remove any debris.
You can also start the machine while it's disconnected from the duct, momentarily to check for proper airflow.
Best of success!
Posted on Nov 26, 2009
Testimonial: "Spot on, its a condenser dryer and the intake filter was blocked. Thank you so much"
Where is the conductivity contact in a Fisher & Paykel DEGX1 dryer? Diagnostics say to run damp fingers or clothes over it to rule out contacts going open circuit, but where are they?
The contacts are on the inside of the drum. Two silver shiny metal strips. When moist clothes cross the strips they complete a circuit.
Nov 07, 2017 | Fisher Dryers
My Fisher Paykel washing machine works well but seems to need two spins to dry properly all of a sudden, blocked pump?
It can be due to insufficient RPM of the dryer or due to water logging within the drum.
Please check this link for tips:Pump
Check the drive for jamming of the spindle.
Jan 22, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel degx1 heats but doesn't run long enough to dry, clothes still damp. I set to extra dry, still no luck. Thermostat, and a couple other parts just recently replaced.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 14, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Bought dryer In October 2007. Now the auto-dry cycle is not doing the job. Clothes are still quite damp when cycle shuts off. The lint bucket is not full and we cleaned out area leading to it along...
You may need to reset the breaker for the heating elements or clean and check the continuity contacts. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 28, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel Dryer is taking 3 hours to dry(DeIX2)
Check your cvent going outside. also check to see if the vent is smashed. try using the time dry cycle and see how your clothes turn out. if they are still wet or damp. you have a heating problem. try those solutions.
Oct 19, 2009 | Dryers
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Dryers Logo
63 people viewed this question
Top Fisher Paykel Dryers Experts
Peter
Melissa Martin
Melissa Martin
Roderick Scott
Roderick Scott
Are you a Fisher Paykel Dryer Expert? Answer questions, earn points and help others
