Question about Frigidaire Refrigerators
Won't stop running. This says I have to end with a ?
FRC05L5DW1 Model Refrigerator always ran way to cold & now won't stop running. Froze everything. Defrosted & still won't stop. Only about 4 years old so I hope this isn't the way all Frigidaire/Electrolux are built.
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRC05L5DW1, is freezing the inside as well as running constantly. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. When power is restored, if you are still having the same issues, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Posted on May 20, 2014
SOURCE: Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
Posted on Mar 09, 2007
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
whytfang
  • 170 Answers
SOURCE: freezer is cold but refrigerator isn't
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Posted on Jun 20, 2009
EllaWatson25
  • 725 Answers
SOURCE: 1 month old Frigidaire model # FRT21IL6JM2 has not
Are you still under warranty? Call the place that sold it to you and ask them for a loaner until this one is repaired or replaced. Most honest places will provide one for you. Hope this answers your question and the best of luck to you, too. Ella
Posted on Aug 26, 2009
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
The evaporator fan is always running at a constent speed . Is this OK
Chances are you won't notice when it shuts off, but it does. The only reason I can say this without seeing the machine is because if it ran all the time, it would run during the defrost cycle as well and if that were the case your complaint would be about how hot the inside of the machine was and how the food was all ruined.
May 30, 2012 | GE GBSC0HCXWW (203 cu ft) Bottom Freezer...
Having found there is no defrost timer on my frigidaire rlr1450 could my problem be the thermostat . on saterday the fridge ran all day and froze everything , switched it off overnight , on sunday it ran...
Yes your refrigerator could and most likely has a thermostat problem. Thermostats go bad in several ways, by not sensing the correct temperature, not working at all or sticking on until fresh food section becomes a freezer. Although I cannot find a Frigidaire Model RIR1450 in the US database that does not mean there is not one worldwide. Your refrigerator does have a thermostat most likely behind the control panel inside the fresh food section, Thanks Sea Breeze
Feb 22, 2012 | Frigidaire Refrigerators
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Feb 16, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
150 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
