Question about Frigidaire Affinity ATF7000ES Front Load Washer
Door gasket is black looks moldy? - Frigidaire Affinity ATF7000ES Front Load Washer
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I see that the door gasket on your Frigidaire Affinity washer, model# ATF7000ES, is black and looks moldy. It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There are a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month, using liquid bleach, on the clean-tub cycle to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a buildup of detergent on the tub which encourages mildew growth.
3. After your final wash of the day, leave the door and laundry detergent open, wipe dry the gasket with a cloth.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
-Best Regards-
WP
Posted on May 20, 2014
2 Suggested Answers
  • 670 Answers
SOURCE: moldy gasket
It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There is a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month using hot water and two cups of vinegar to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a build up of detergent on the tub which encourages mildew growth.
4. If the above steps does not help, try a commercial product like Affresh.
Hope this helps you.
Posted on Jul 22, 2010
Kenmore elite HE4 moldy smell
keep door open after you use it....keep them open until you use it again.... door can be opened just a little, but can not be closed
let machine work once with highest temperature without anything inside..... with little detergent you always use.....to wash away that smell...
if you keep it closed, then moisture will remain in and provide good environment to bacteria causing black mold to live there.....
you can remove that only mechanically..... take some old dry dampcloth and wipe it away.... it will take some time and hard work.:)
Jan 13, 2014 | Kenmore Elite 45986 Front Load Washer
Moldy rubber door gasket
clean it with a water bleach mixture and make sure the door boot drain in the bottom of the boot isn't plugged with lint,soap,etc and can fully drain
Nov 18, 2010 | Maytag Washing Machines
Moldy gasket
Jul 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Replace door gasket lg wm2277hw
Hiya,
you can find spares for this machine on espares i think the gasket will be a universal one but here is a link for you to check
http://www.espares.co.uk/parts/lg/p/0/81?k=wm2277hw+door+gasket
Please note i have not used this site before but i have noticed that they will deliver to most countrys & im sure they will be able to help with a fitting tool issue if you contact them.
Hope this helps
Apr 20, 2010 | LG WM-2277HW Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do I get rid of the black mold on the door gasket?
If you take a bit of tilex mold/mildew spray and a rag, you should be able to remove it all.
Also , look down at the bottom of the front "gutter" just in front of the tub. There is a series of drain holes and clothes lint can build up a bit in here. take a towel and wipe the holes really clean . This will help keep the water draining out of the front and keep the moldy smell to a minimum.
One last thing, I've found with my front loader, that if I keep my wash loads to a medium full size instead of completely jammed full load size, the drain/mold issue is almost non-existent.
Hope this clean it all up for you!
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load kenmore washer
Run an empty load with bleach and detergent and/or ammonia on hot.
Dec 21, 2008 | Washing Machines
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
