Question about Furniture
How to assemble a HON 34000 desk
Install legs on HON 34000 desk
How to secure desk legs
They most likely screw in.
Sep 19, 2014 | Computers & Internet
What is an executive desk?
An executive desk has a wide flat surface and drawers on the sides. These desks are great for people who need a lot of work space. They are most commonly made from wood (cherry and mahogany).
Aug 15, 2012 | Furniture
My tomtom no gps signal
check that the port and baude rate are set correctly see the manual
i recall that the standard port was 8 and the bause rate 34000 NMEA
if none of the port changes work its either a low battery power or a damaged SIIRF chip which costs arms and legs to repair
Jun 16, 2009 | Tomtom ONE GPS Receiver
2005 elantra need answer on removing rotors
REMOVAL:
Loosen the wheel nuts slightly. Raise the front of the vehicle, and make sure it is securely supported.
Remove the front wheel and tire from front hub.
Remove the split pin, then remove castle nut and washer from the front hub while applying the brake.
Remove the caliper mounting bolts, and hang the caliper assembly to one side. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper from the undercarriage.
Remove the wheel speed sensor from the knuckle.
Disconnect the tie rod end ball joint from the knuckle using the special tool (09568-34000).
Remove the split pin.
Remove the castle nut.
Disconnect the ball joint from knuckle using the special tool (09568-34000).
Remove the lower arm ball joint mounting bolts
Remove the strut lower arm mounting bolts
Remove the hub and the knuckle assembly
INSTALLATION:
Reverse the order of the removal procedure.
May 23, 2009 | 2005 Hyundai Elantra
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Sound Driver
If you are reinstalling Vista it can be found here - http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=3645611
If XP then download and then install these three in order.
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33742.exe
May 06, 2008 | Computers & Internet
Furniture Logo
61 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
