Question about Kenmore Elite 45986 Front Load Washer
Why on kenmore washer model#41743042200 will it not drain,stops due to making noise like stuck
Starts to spin,wont push water out,sounds like it is stuck,makes a weary noise,when getting to spin cycle,sounds stuck''
mikedurland
  • 481 Answers
SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Posted on Aug 04, 2008
SOURCE: Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Posted on Dec 11, 2008
SOURCE: Kenmore 70 series Washer will not go to spin cycle
i had the same problem and agree that the lid switch is probably shot. Try putting some type of weight on the lid right over the switch when it gets to a spin cycle. If the machine starts spinning, that's the problem.
Posted on Dec 16, 2008
  • 109 Answers
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Posted on Jun 16, 2009
kvhappliance
  • 218 Answers
SOURCE: Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Posted on Mar 22, 2010
Series 70 fills wit water stops then makes a slight buzzing sound
Jun 16, 2009 | Kenmore Washing Machines
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer makes noise but, wont drain or spin
Check the lid switch (the part that gets pushed down when you close the lid). Try pushing it down with something. If you do not hear it make a CLICK sound, then it needs to be replaced.
Note: ALWAYS unplug appliances before attempting to make any repairs!!
Mar 14, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
No-spin and noise
ok first it sounds like something is stuck in your drain pump first if you have a shop vac then vac out the water through the drain line then tape the lid shut and lay the washer on its back to service also on the front panel on the inside will be a tech sheet there good luck
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
