Question about Duravit Home
How can I install Duravit single flush button with Geberit single flush valve?
I took the lid off, screwed plastic fitting in & replaced lid, button rim & button center. All looks good, but flush valve will not respond: position of plastic screw into valve does not seem correct.
freetek
  • 5568 Answers
SOURCE: tripod screw
I once had an adaptor that would allow this kind of transition but it is odd that a Sony would have ASA threads instead of metric.
If you have a major camera shop (not Mall-wart) nearby they should have these.
If not, check with Ritz or Beach Camera.
As a last resort, the major chain 'home-improvement' stores may have 'wing screws' that could work.
Posted on Aug 05, 2008
SOURCE: Plastic handle Rival slow cooker model 38511 broken
The problem is the threads strip on the bolt and nut. I took these to Home Depot's specialty fastener section (the one with the drawers of stuff) and purchased a nylon bolt and nylon wing nut and solved the problem. I is easy to remove for cleaning and all is dishwasher safe.
Posted on Jun 12, 2009
  • 69 Answers
SOURCE: A part of a Top Elite double flush cistern has snapped
Yes
Posted on Oct 07, 2009
SOURCE: 2002 camry - Need to replace broken console lid
Solved it. Found a small shank screwdriver that fitted into the opening with a little bending of the plastic frame. managed to replace it with a new one without trouble. No further help needed. dave
Posted on Nov 09, 2009
  • 15190 Answers
SOURCE: Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Posted on Mar 02, 2010
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
Aug 23, 2011 | Duravit 111335001 Geberit In Wall Carrier...
OUr 5 yr old duravit toilet is constantly running. Seems that tank water is seeping into bowl causing the mechanism to demand more water. Onl way to stop is to turn of water valve until we need. Before I...
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case   a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 16, 2010 | Duravit Tribeca US-Type Elongated Toilet...
How to remove lid on Kohler k-1833a cistern
Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
Jan 12, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
My toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. bigslimaba@yahoo.com
Jan 11, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
50 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
