Why wont my new zoostorm g32220 computer work? all connected to power supply but not working
3 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: e-machine t2682 desktop
cpu setting in good jumper on mobo set on 1 2 pin not 2 3 for reset ? could be bad mobo what socket mobo do uuusse
Posted on Jan 21, 2008
jryc32
  • 408 Answers
SOURCE: i reset my surge protector
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Posted on Sep 09, 2011
    Zoostorm
    plz go to device manager in control panel and reinstall the sound card....just delete the sound card and refresh may be it will ask for driver so put the cd in the drive which comes with the computer..hope solve ur problem
    May 15, 2014 | Computers & Internet
    Zoostorm playtab only works on mains power indicator states battery fully charged
    Did you manage to fix this problem? I have the same problem with my tablet.
    Dec 12, 2013 | Tablets & eReaders
    My Zoostorm Desktop won't boot and show up on the monitor. Help?
    No signal just means the video card isn't putting out any signal. If you don't even see BIOS then replace the power supply first. Still doesn't work then it's probably the motherboard.
    Jan 01, 2013 | Computers & Internet
    How to wirelessly connect zoostorm G530
    The USB one should work. The computer should detect it and automatically install the driver. If you have a disk with it try that. Once the computer has installed the adapter you need to wirelessly connect it. The old school way is to see your router in the listed stations, click on it and then supply the correct key. The new way of doing it is to use the magic button on the router itself which unlocks it for 2 minutes. Then when you click on the router listed it just lets you in.
    Oct 22, 2017 | Computers & Internet
    My zoostorm netbook wont shut down i really need help with this thanks.
    Perform a hard shut down on your computer by holding the power button down for roughly 6-8 seconds. After that, take out the battery and unplug the power cord. Once that is done, hold the power button down for 10-15 seconds. This will reset the computers cache. This might solve your computers not shutting down issue.
    Mar 13, 2011 | Compaq Presario CQ60-220US PC Laptop
    Wont boot
    Check power Supply as it might have shortened the power, Open the case and remove the big white power lead from the motherboard (this is clearly visible as all the colored leads re and yellow from the power supply - normally a P4 feed into the socket).
    Unplug this, find another power supply and using the big white cable connect this to the motherboard and try powering the machine up with that.
    If works - great just replace all power cables from the power supply in your machine with the ones from the working one (not forgetting to remove the old power supply from the computer and replacing it with new one).
    This should work
    Sep 20, 2009 | HP Compaq Presario SR2011WM PC Desktop
    Computer wont boot up
    what is your computer doing?
    Dec 16, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
