Panasonic NA-F70G2X foultcoad U11 - Washing Machines
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
U11 error code panasonic md 9000
i am 100% sure that it is the play head of your md 9000 that is dirty or faulty
solution
1)get a play head cleaner,put your cam in playback mode then play it to the end,then you can now confirm with a new tape
2)if solution 1 do not solve your problem you need to change the play head of the cam
Sep 19, 2011 | Panasonic NV-MD9000EN Mini DV Digital...
Panasonic washing machine NA-168vg3 stopped with 31 mins to go giving error code U11
U11 is inability to drain. Check your filter. Check your outlet hose. If you can blow down it, then your pump's jammed. I just found headless metal rivet type pin in the pump. Take the drain flap off, and remove the screw. This whole width panel now moves off to the left.Lean the machine on it's side, take off the black plastic plate. Remove the two screws from either side of the filer on the front. Pump is now loose. Remove the three screws on each pump and check if anything is stuck in the impellers.
Refitting is the reverse.
I know this is an old post, but someone may find this useful!
May 18, 2011 | Microwave Ovens
My panasonic dvd player is displaying error u11 code wont play any dvd's
If you are trying to run a recorded DVD (saved a video or movie on to it), it could be the quality of the disc. I would recommend buying quality DVD's, the lower quality ones can create read errors (U11).
Jan 25, 2011 | Panasonic Televison & Video
Got error code u11
Mar 12, 2009 | Washing Machines
It reads u11
U11 means "incompatible disc"
Either you are trying to read a disc outside your region (region 1 discs required for U.S.) or the player has gone bad.
Jul 09, 2008 | Panasonic Televison & Video
I have a panasonic dvd recorder modol dmr-e30 when i load the dvd i get the error message u11 how can i resolve this problem.
Has anyone found a solution? I was recording movies everyday and then it stopped and says U11. I am using the same discs as before.
Jul 02, 2008 | Panasonic Televison & Video
U11 Error and Clicking
hi i try to this,but nothing still the same!!!!
Oct 28, 2007 | Panasonic DMR-E30 DVD Recorder
Dvd-s325
Does anyone have information about
IC MR6710 datasheet and/or where to order it?
It is an power sply device of PANASONIC S325 DVD Player.
Tank u in advance.
starnazza_beppe@libero.it
Aug 22, 2007 | Panasonic DVD-S325 DVD Player
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
