Question about Arrow Tools & Hardware - Others
ARROW ETFX50 284C manual
How do you remove a jammed 1/2" staple
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
SOURCE: how to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Posted on Aug 20, 2009
  • 32 Answers
SOURCE: my arrow staple gun jams every few staples even
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Posted on Nov 10, 2009
farmerbear
  • 490 Answers
SOURCE: Just purchased t27 arrow staple
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Posted on Aug 24, 2010
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
Can u tell me how to load the staples into my arrow t25 staple gun not used it for a long time
Hello. Here is a link to a free manual for your stapler. http://www.arrowfastener.com/upload/manuals/79055000259_manual.pdf
Look on page 3 for the three steps to load it.
1. Press latch in lower rear of gun to remove pusher rod from machine.
2. Insert strip of staples.
3. Replace pusher rod.
Happy stapling! J.
Jun 22, 2010 | Arrow T25 Staple Gun
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
My arrow staple gun jams every few staples even thought it has a ''jam proof mech''
Nov 10, 2009 | Arrow T50P ARROW STAPLE GUN
How to repair jammed arrow electo matic staple gun
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
How to remove jammed staples in staple gun?
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Tools & Hardware - Others Logo
61 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
