Question about Toro Power Lawn Mower
Toro lawn mower runs and stops
The mower runs less than a minute and stops. It also surges New spark plug drained fuel cleaned carb
  • 69 Answers
SOURCE: My Toro lawn mower starts good, but it only runs
Sounds like you need a carb cleaning. Also install some Seafoam gas additive in your gas tank to clean out the gunk that builds up. Do not use ethanol gas.
Posted on May 18, 2009
heres2maine
  • 84 Answers
SOURCE: Have a Toro LX 465 lawn tractor, won't start;
Could be your coil. Might be bad or it went out of gap. Gap is .10
Posted on Jul 10, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a toro lawn
Remove the float bowl on the carb and remove the debris from the float bowl. Also in the very bottom of the carb where the float bowl attach nut screws in there is a jet. Take some carb cleaner and shoot into the hole to remove any debris from the jet.
I note you say you changed the spark plug. Is the problem fuel or spark related? It appears to be a fuel issue.
Also if we have to go beyond this post and I will gladly do so to resolve your mower problem. (I have over 40 years of hands on and in shop experience.) I really need your engine model number vs the Mower model number after this. Toro uses 2 different engines on that model of mower.
Thanks for choosing FixYa.
Kelly
Posted on Aug 30, 2010
rycgl
  • 1545 Answers
SOURCE: I have a Toro Super Recycler Mdl 20033 ser
You may not need to change the ignition module. The "air-gap" on it may just need to be adjusted. That is, the distance between the pickup legs of the ignition module and the magnets integrated into the flywheel. You would have to remove the exterior cover and any sheet metal cowling (directs air flow off the flywheel around the engines cylinder). Then, the coil and flywheel should be visible. I use a standard business card as a gauge. Slide it between the coil legs and the magnet area of the flywheel. You should feel just a slight little rub. If it won't slide or the gap is large, no spark will be produced. You will have to loosen the screws holding the coil in place, double up the card. let the magnets pull the legs in against the card with magnets behind and retighten. Then recheck for spark. Post back if needed.
Posted on Apr 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a Toro GTS5 Super Recycler mower model
Hi ricks7...
I also believe that it is a problem with the jets.
Try some of these solutions
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 28, 2011
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
I have a Honda HRR216TDA lawn mower that starts and then stops and wont stay running i have replaced the spark plug and drained the fuel tank and checked all of the lines. Could the problem be a clogged...
More along the lines of a dirty carb. Replacements run about $32 online, sometimes less. If you know what your doing, remove the carb, pull the bowl and spray clean it with carb cleaner. You will see a small plastic screw on the side of the carb holding down a black plastic piece, remove the screw and pull the plug - spray that clean also. Recommend replacing all gaskets when reinstalling the carb.
Aug 08, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
16 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
