Question about Garden
Flymo power compact 330
Flymo turn off when only half full. Used to turn off when full up
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 256 Answers
Test your actuator. I see this a lot on walker machines
Posted on Jul 06, 2014
  • 109 Answers
SOURCE: can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Posted on Apr 16, 2009
jj505
  • 195 Answers
SOURCE: my lawn mower doesn't start -
You must check for a short in motor.
Posted on May 07, 2009
  • 402 Answers
SOURCE: Blades keep spinning out on Flymo
Replace the disc.
Posted on Aug 28, 2009
AUTODOC01
  • 216 Answers
SOURCE: flymo quicksilver 46s keeps cutting out
make sure button not cracked also fuel filter sits in bottom of tank get you a peice of coat hanger and fish it out just pulls off the end clean it good and also double check your carb sometime you can lose a gasket and it will cause similar issues? let me know if any of this helps ? can also tell you how to adjust high speed side of carb if all else fails?
Posted on Aug 29, 2009
Testimonial: "that was very usefull thank you"
SOURCE: My flymo gl47 does not get up to max revs,any
you can adjust the rpm on the carb underneath the fuel tank
Posted on May 06, 2010
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
May 17, 2014 | Garden
the upper section of the grass collection box is a fill indicator. this indicator shows green and turns red when full. it also triggers a power off switch. it sounds like some debris has caught between the switch and indicator.
with a fine dry small paint brush or cotton bud clean around the switch .
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
Switch for hover mower 300mm 1250w
Hi and welcome to FixYa, I am Kelly.
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
This is the Flymo manual:
http://www.shop.flymo.co.uk/images/mediator/397/oipl2002_p0201018.pdf
This is the switch for the Flymo Hover mowers:
http://www.espares.co.uk/part/lawnmowers/flymo/turbo-compact-330/p/1116/283/116/402362/1136941/8a-250v-lawnmower-switch.html
This was my best mind reading guess. If this is not your brand then help us help you by responding with a make and model number please.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Garden
No power when switched on.
sounds like the engine isnt getting the power to turn it sorry but flymo mowewrs are a pain to repair as they some times cost more to do than buy a new one
Jul 10, 2010 | Garden
My lawn mower doesn't start -all wires and cords are ok - and then sometimes it starts itself and when i move it it stops again. it was working perfectly fine one day and then the next....its gone it's a...
sometimes you get an internal break of the electric feed cable which shorts out with movement and gives problem that you are having , another fault with them is that the switch has a safety machanism in it which can cut power for up to twenty minutes before it will reset which is done by operating lever as you would normally ,occurs a lot with m/cs used with adittional extension cables,hope this helps
Mar 23, 2009 | Electric Lawn Mower
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
