Within mobility scooters, error codes tend to be shared
Error 7. Speed Pot Fault.
The throttle, speed limit pot, SRW or their associated wiring may be faulty. ? Check the throttle and speed pot and associated connections and wiring.
hi Ruben,, if it sounds like the horn button is pressed maybe not that loud , then you got water in the horn button that is conducting , carefully take a hairdryer and warm the button etc and I mean warm not hot!, remember its plastic ..
if it's a beep pause beep and so on, it the scooter telling you the batteries are low ...
The loud whining noise is just normal for vfr 400 because it is gear driven cam.. As you reach 5000rpm up, the bike's electrics try to misfire the plugs so it would act as a speed limiter (180kph).. You have to bypass the sensor at the speedo..
