Question about Frigidaire FAFW3001LW Front Load Washer & FAQE7111LW Electric Dryer
Fafw3001lw1 washer problems - Frigidaire FAFW3001LW Front Load Washer & FAQE7111LW Electric Dryer
  • Frigidaire
    Frigidaire May 20, 2014
    Good Afternoon Friend, I understand you are having trouble with your Frigidaire washer, model# FAFW3001LW1. I will be more than happy to assist you. If you could please give me some detailed descriptions of what is happening with your washer, this way I am able to better assist you. Looking forward to hearing from you. WP
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
F- code does not show code in book what and how to remedy the problem?
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have A WhirlPool Cabrio.. when i start a load.. it flashes "FL' and beeps excessively.. how can i fix and prevent that?
Feb 20, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
My washer makes a groaning noise when spinning. any advice on what the problem might be?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
No windshield washer fluid pumping
1) Fluid resevoir is empty
2) Fluid is frozen
3) Washer fluid hose is disconnected, blocked or kinked
4) Washer switch is faulty
5) Washer pump motor is defective
6) Washer pump fuse is blown
Dec 24, 2010 | 2003 Oldsmobile Alero
This kenmore washer makes my towels smell horrible this has been a problem for the two years I have had the washer. I can't take it anymore
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Sep 03, 2010 | Kenmore HE2 Plus Front Load Washer
Windscren washer not working on my peugot207cc
Check the fuse for windscreen washer.
If you can hear the washer motor running but no water comes out then check the washer motor under the side wing cover.
Pull the rubber pipe from motor and then let the washer run to check wheather water will be pumped or not.
If yes the problem is on the side of rubber-pipe to spray-jets on bonet (may be spray jets need some cleaning).
If not then then the problem is in washer pump. The dirt that reside during the time inside washer pump (the plastic pump attached to the washer motor) causing the problem.
Pull out the whole pump motor from tank and disassemble the pump to clean the free moveable conical metal rod and rubber washers (takes about 1.5 hours for cleaning). If you don't want to do it then convenient is to buy another washer (set of motor+pump).
Jan 16, 2010 | 2006 Peugeot 405
Kenmore 700 series top load washer problem
Take the washer back. We just bought the same one and have the same problem
Feb 18, 2008 | Washing Machines
Frigidaire FAFW3001LW Front Load Washer & FAQE7111LW Electric Dryer Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
