V-129118-02-47
SOURCE: Vacuum making loud noise
It could be 1 of 3 things:
1. The belt that drives the beater bar. (Inexpensive)
2. An impeller that has a broken wing or 2, throwing it off balance. (Expensive)
3. Or, the bearings in the motor are going out. (Expensive)
Hope this helps,
Jim
SOURCE: vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
