Question about Sylvania G-Netbook
I cannot start the boot - Sylvania G-Netbook
How do i redirect the boot manager on PRESARIO CQ56
Its all depends on your bios version but basically you need to press F12 or F2 When it starts up. Its the key to access your boot / configuration manager. you can choose your first booting device from the boot menu.
NDK
Jul 20, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
How to by pass boot device menu at startup?
On boot, press F2 and go to the Boot section of the BIOS then select the correct order for booting.
Feb 17, 2012 | Toshiba Computers & Internet
I wanted to remove network boot from bios setup to normal cd rom boot
Hi
When you start the computer click F2 to inter the Bios setup
then go to boot menu and choose boot order make the first boot for CD Drive
there's kind of MB contain boot menu you can reach it by click F12 when you start the PC
Apr 24, 2011 | Intel Computers & Internet
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
Wont boot up completly, keeps re-booting itself
press F8 before the booting screen appears.there u will find option to start the computer in safe mode
Apr 06, 2010 | Computers & Internet
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
Does not boot normally
when you bootup click on F8 then boot up in safe mode and see it will boot up
Mar 24, 2009 | Computers & Internet
PC keeps booting but doesn't start up
Easy fix! Put the windows boot disk in the optical drive. It will either start up of you can re-install windows. Easy Solution!
Jan 27, 2009 | Dell Dimension 2400 PC Desktop
Sylvania G-Netbook Logo
98 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
