Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
We have a Maytag Epic Z front load washing machine that is making a loud metallic noise during the spin cycle. The noise migrates radially around the tub as the drum spins. It sounds like pocket change making a trip between the drum and tub (could be a nut or bolt too....who knows). The noise is not in a fixed location so I'm sure it's not a bearing or pump issue yet. Is there a way to seperate the inner basket from the outer tub on a front loader to remove this foreign object?
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Rattle no more. If only I could find the solution for affording a trip to Europe as easily.
Posted on Jul 12, 2012
Did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Posted on Jul 24, 2010
2 Suggested Answers
SOURCE: We have a Maytag Epic Z front load washing machine
You better not to separate the inner and outer tubs as it's quite a job and takes a lot of effort.
Try to remove the heater on the very bottom of the front half of the outer tub. From outside it looks like an oval metal piece with a terminal on each side, a nut (or screw) in the center and a plug with 2 wires coming to it. UNPLUG THE WASHER as the heater is connected to the hot wire all the time.
Remove the nut (or screw) in the center of the heater and pull the heater out. Now you have a nice opening in the bottom between the tubs. There is a heater bracket, made of a thick wire inside. Make sure not to damage it when trying to remove whatever there is inside. Make sure the heater is aligned in the bracket when assembling it back together.
Good luck.
Posted on Oct 13, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
We have a Maytag Epic Z front load washing machine that is making a loud metallic noise during the spin cycle. The noise migrates radially around the tub as the drum spins. It sounds like pocket change...
Good luck.
Oct 13, 2009 | Maytag EPIC MFW9700S Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,404 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
