Question about SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal
Hard drive dose not show up my computer
Computer does not recognize hard drive
Hello, I bought a 250 wd and it is not recognized on my powerbook g4. I have a USB 2.0 cable. Can you help? Also, it does not show up on desktop or on Disk utility.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files. get the data recovery program from
http://www.asoftech.com/adr/
Sep 05, 2011 | Western Digital 250GB ELEMENTS EXTERNAL...
My computer do not recognize the toshiba roco HDD
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from external hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Toshiba 120GB USB 2.0 Portable External...
My computer doesnt recognize Fantom Drive titanium II. i am having windows 7 installed in my system. please help how to solve this problem
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Fantom Titanium II (TFD250U8) 250 GB USB...
My external hard disk is not working properly. i can see the icon in drivers and printers but there is no folderor icon to open
Please remove the usb cable and try to connect do you see the notification new hardware found if yes just check my computer dose the hard drive shows over there if yes and double click on it dose it open if yes and the hard drive is empty .
then go back right click on the hard drive check properties dose it show the empty and the full graphs if it shows full and dosnt show the drive letter.
then right click on the my computer icon on the desktop go to manage and diskmanage ment check the hard drive over ther dose it show its unformated or un initialized if no dose it have drive letter on it if no then right click on the drive and say change drive letter and assigned one letter like h or g and check in my computer now dose it appair.if still so try changing the usb cable may its defective.
if dosent detect at all could be your hard drive case so you can remove the hard drive from inside the case and connect it directly.in the computer if works backup your data abd return backthe hard drive in the case and if its still in gurentee return it to the service center.
Dec 14, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Unit is on but, will not show on my computer
what could be the solution of acfaulty hard disk?
Mar 16, 2009 | Maxtor Hard Drive
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
500g harddrive
It broken. if you want your data back youl have to spend alot on data recovery.
Jul 24, 2008 | Western Digital My Book Essential Edition...
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal Logo
44 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
