I hooked up a HP 4180 Photosmart printer-copier to a new Mac Mini. The scanner works but when I go to print it is stuck in "stopped" and I get the message "client-error-not possible"
When you say "the scanner works" do you mean you can make a photocopy OR you can scan a file into the computer?
Many people think scanning means copying. They are not the same. If you can scan a file into the computer then your connections are sound and the problem lies with the printer driver side of things
Normally this is the procedure on a mac:- go to the printer set-up panel in System preferences. If the printer is listed, highlight it and then delete it.
Click on the plus symbol to add a printer. If the computer can see the printer it will automatically add it to the list. If the correct driver is available it will load by itself.
See if you can print now.
NOTE: we have not used any CDs yet. My experience with HPs is that generally the software on the CD is not up to date and that supplied in the Mac is generally more up to date.
If it still doesn't work then go to the HP website and download the latest driver you can find and install it. Then go through the routine above once again.
hp 4180 will scan but won't print, error cannot find printer, tried disconnecting/connecting,...
(More)
hp 4180 will scan but won't print, error cannot find printer, tried disconnecting/connecting, remove/reinstall, no fix
Had to restore the computer, because of problems. Now I can not get my HP 4180 all in one to work. I...
(More)
Had to restore the computer, because of problems. Now I can not get my HP 4180 all in one to work. I put the disk in, and it says that the computer does not meet the requirements. Please help
Screen shows :printer ready, But when requested to print "Carriage Jam" appears, Both with...
(More)
Screen shows :printer ready, But when requested to print "Carriage Jam" appears, Both with and without paper, and when opening back cover there is no paper jammed
