Question about Car Audio & Video
Installing new speakers, How do I remove the front door panels to access the speakers
  • dan_lewis Jun 24, 2009
    I have a 2005 pontiac grand am 4dr 3.4 lt v6 sedan with auto lock & windows. I need to replace the factory front speakers in the front doors. How do i remove the front door panels to access the factory speakers.
  • dan_lewis Jun 25, 2009
    I have a 2005 Pontiac grand am 4dr 3.4lt sedan. What is the stereo speaker wiring harness color code for this vehicle?
    Top Expert:
  • Car Audio & ... Master
  • 81,285 Answers
Okay, I currently have a 2004 Pontiac Grand Am GT1. I went to go replace my stock speakers and found it quite difficult. Here is how I removed the door panel and got access to the speaker holster: (I SUGGEST DOING IT FIRST ON THE PASSENGER SIDE WHERE THERE ARE LESS WIRES AND COMPONENTS) 1) Take off the tweeter (triangular thing). It is simply clipped on and will come off relatively easily. Pinch inward and pull out. 2) Then proceed to roll down the window ALL THE WAY. This will prevent you from scratching or shattering the window if a tool slips. Next, pop off the window and lock control panel (with a flat-head screw driver) off the door panel (it is simply clipped in with 2 metal tabs on each side to hold it in) to reveal the inside of the door and ONE LARGE SCREW. 3) Start to take off the door panel screws. From what I remember, these are the screws and their locations: (in order) a) Small screw holding in door handle cover. (this removes the protective door handle thing)(the protective thing needs to be removed: simply pull on the handle while slipping the cover out.) b) Large screw under the handle of the door. (this will loosen the whole panel) c) Large screw UNDER the reflector plate on the door. You will have to take off the reflector in order to gain access to this screw. CAUTION: the reflector is VERY fragile and can crack easily. (this will loosen the whole panel) d) Large screw right behind the window controls. (this will disconnect the whole panel from the door itself. DO NOT TRY TO REMOVE THE PANEL WITHOUT REMOVING ALL THE SCREWS AND THE PROTECTIVE PLATE!!! 4) Electronic Obstacles...yea...kinda hard to explain: Well, first off, the panel will not be able to come off without disconnecting the door control panel. Since you already popped off the window controls, all you need to do is disconnect the adapter that the wires plug into. On the passenger side, this is easy, simply pinch in on the two connectors and pull out. These "ribbons" may need a bit of convincing, but they DO come off. The driver's side electronics are EXTREMELY complex and are EXTREMELY hard to take off, to tell you the truth, I only rotated the disconnected door 90 degrees which left just enough room to solder and install the speakers. I did this so that I didn't need to disconnect ANY parts of the door controls on the driver's side. I only needed to pop off the window control panel, no disconnection of any wires. (the driver's side wires seem to have more slack than the passenger ones. I found this easy with two people. 5) Now for the hardest part, taking off the door panel itself. The whole panel is held on by white PLASTIC bolts that are ribbed. These bolts can be pretty annoying, but secure the door quite well. First, I started by the tweeter. There should be a small space where you can fit a hand in and start pulling. DO NOT PULL OR TRY TO PULL ALONG THE TOP OF THE DOOR, START YOUR HAND ON THE TOP BY THE TWEETER AND WORK YOUR WAY DOWN TO THE BOTTOM OF THE TWEETER SIDE (while hand still between the panel and the door itself). THEN START PULLING ONCE YOU ARE AT THE BOTTOM OF THE DOOR PANEL. As you work your hand down the door, you might here a sound of breaking plastic, this is what you are looking for. The ribbed bolts are being pulled out of their holes. Eventually, once a majorority of a side is out, it will make it MUCH MUCH easier to pull the remaining bolts out. Once you get the hang of hearing the bolts come out, and you are able to get a bigger grip on the panel, the whole door will eventually POP off. Now that it is popped, lift the panel up and it then should come off cleanly.
  • NOTE* - You WILL NEED a Torx wrench to replace the speaker ($4 at home depot)
Posted on Jun 25, 2009
    President:
  • 392 Answers
First pop off the panel that has all your power windows and locks on it. behind it you will find a phillips head screw. take that out. also remove all the wires going to the switch panel. there are 3 all together (if you have power locks windows and mirros) and there all pretty easy to get off. next take the screw off behind the door handle. this is also a phillips head, but its smaller. ok if you see your "oh sh*t" handle there is a hole that goes into it twords the bottom of the handle. its the same type of screw that was behind the electric panel. last thing to do is take a small flathead, and pop out the reflector at the end of the panel. be careful with this, as its very easy to break. the last screw is behind that, and its the same size as the other 2. now, if you run your hand under the bottom of the panel, you'll feel a notch cut out of it. grab it, and give the panel a good yank. it should come off. if not try again with more force.once you've got it off get your credit card and your good to go. when you put it back on do so carefully. make sure to line the white plastic tabs up with there holes, other wise they will break and the panel might rattle. once you get them all lined up, hit the panel all around the clips a couple of times. then put the screws and electric in and your good.
Good Luck. U will do it ..
Please rate my solution for which i will be paid for the service done. Thank u
Posted on Jun 24, 2009
  • 854 Answers
Try this
Posted on Jun 23, 2009
How do I replace front speakers in my 2008 Saturn vue
door panels are easy their is just plastic push pins that hold panel on go around panels and pry them out slowy working arounf the door. no need to remove it entirely you will now have access to your speakers . simply remove them and replace them pop panel back on gently .
Auto Repair Mechanics How to Remove Car Door Panel Here is a good link for you to watch and get the gist of it hope i helped you.
Sep 27, 2014 | Car Audio & Video
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  1. Disconnect the negative battery cable.
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
Mar 24, 2010 | 2002 Ford Explorer
How do I replace speakers on a 1994 xj6 ?
Replacement of Front and Rear Door Speakers
Required Tools:
#2 Phillips Screwdriver (magnetic tip is useful)
9 mm Nut Driver
8” or 10” Flat Tip Screwdriver
Small awl or other sharp pointed instrument
Soldering Iron w/solder or 8 to 10 small wire **** splices
8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
Thread locking compound “Loctite” (optional)
6” wooden dowel of ½” diameter to be used as a drift
Small mallet or hammer
1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
3) Remove the Upper Inner Door Panels as follows:
It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
4) Remove the Lower Inner Door Panels as follows:
a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
5) Remove Door Mounted Speaker as follows:
a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
6) Install New Door Mounted Speaker as follows:
Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
8) Perform Steps 3 through 6 for the other doors and the job is complete.
9) Remove Rear Footwell Mounted Speaker as follows:
This sequence is good for both 4” and 5.25” footwell mounted woofers.
a) Using a small flat screwdriver as a lever, carefully ease off the grill.
b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
c) Ease out the old speaker and release the electrical connector for the speaker wires.
d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
e) Re-connect the speaker wires to the harness by joining the electrical connector.
f) Mount the new speaker and re-attach the necessary sheet metal screws.
g) Press the speaker grill into place.
h) Repeat Steps 9a though 9g for the other footwell speaker.
Mar 10, 2010 | 1994 Jaguar XJ6
HOw do I replace front speakers on 1991 brougham?
you'll need to remove the door Panel to access the door speakers,the door panel will be held in with several screws.
I believe the Front Door Speakers in a brougham of that year are 4x6".
Mar 04, 2010 | 1991 Cadillac Brougham
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
Front door speakers
I just replaced mine on my 2002 Diamante LS yesterday. It really isn't that difficult. To get to the front door speaker you will need to remove the door trim panel. This is done by pulling out on the bottom part of the panel. I used a flathead screwdriver to help with the separation. Just be careful not to scratch anything.
There are 4 or 5 clips that lock the panel on to the door frame. After you have pulled the clips out you will want to lift up on the separated panel as it hangs on a rail adjacent to the window. Pull the panel out far enough to reach behind and disconnect the various wiring clips. They have quick disconnect fittings and come out easily. You will also need to disconnect the door interior light by rotating the base about a half turn to get it out of the removable panel.
Once you have removed the door panel you will have full access to the speaker frame mounting. It has a removable plastic frame that you screw the new speakers in to. It attaches to the door frame with 5 or 6 Phillips type screws. I found it easier to remove the mount and get it ready to accept my new speakers. I just srewed it back on before actually attaching the speakers.
While the dealer spec for door speakers on a Diamante is a 6 3/4" speaker, a 6 1/2" will work just fine if you have a drill to pre-drill new screw holes. Just line the new speaker up on the speaker mount, mark where the new holes should be and then go ahead and drill them. Make sure the drill bit isn't bigger the the screw. It is a machine type of a thread and is easy to self thread with a regular phillips screwdriver.
After you have the speaker mount ready to accept your new speaker you can go back to your car, screw the mount back on to the door frame. Next attach the two speaker wires to the back of the new speaker. White goes to the positive post. (You might need to change the fitting type to match the car wiring and the new speaker) You can get some quick connect friction fittings and put one on the end of each wire that attaches to the speaker. Walmart, Autozone, Radio Shack all have these as they are readily available.
With the speakers in place, just reverse you installation of the door panel. I found it was easier to roll the window down so I could hang the panel back on the channel. Line up the clips and the bottom of the door, push in and you will feel and hear them engage. Once you are sure they are lined up correctly, go ahead and give it a good push where each clip attaches to make sure its on tight.
All done, enjoy your new sound system.
Oct 02, 2008 | 2004 Mitsubishi Diamante
Remove the electric mirror switch
Remove the front door speaker. For additional information, refer to Section 415-00.
Remove the speaker watershield.
Remove the 2 speaker standoffs.
If equipped, remove the window regulator handle.
Separate the handle cover from the handle.
Remove the screw.
Remove the window regulator handle.
Remove the spacer.
Remove the window control switch. For additional information, refer to Section 501-11.
Remove the bolt.
Remove the 2 front door lower bolts.
Remove the door handle cover plate.
Remove the 2 door handle screws.
Remove the front door handle.
Guide the door handle through the opening in the trim panel.
CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
Lift upward to remove the front door trim panel.
To install, reverse the removal procedure.
Jun 22, 2008 | 1992 Ford Explorer
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
