Question about Samsung Televison & Video
Aa59 00607a how to open it , for repairing
Why does Power Point keep trying to repair file?
I'd probably let it run the repair then do a Save As and resave the file. Hopefully that will resolve it.
Or try resolve this by opening the Presentation file in google documents and then resaving it. Or try repair file via PowerPoint Repair Kit. I think something should help. http://www.oemailrecovery.com/powerpoint_recovery.html
See if the following article would help:
https://social.technet.microsoft.com/Forums/en-US/cc126325-068d-4c67-85cf-88fb20e35876/ppt-corrupted-fonts-changed-images-swopped-for-no-reason?forum=officesetupdeployprevious
Feb 16, 2016 | Microsoftoffice 2010 Home & Student Sku...
Prompt the good instrument of repair of Excel Files?
You can try XLSX Repair Kit ( - MS Excel XLSX repair tool ) - XLSX file repair software for corrupt Excel workbook. XLSX Repair Kit helps to repair XLSX file content ASAP.
Jan 31, 2016 | Acer Aspire One PC Notebook
How Repair of Excel file?
If there was such problem, the simplest decision is described here:
http://www.excel.repair/ - Excel Repair Kit. A Microsoft Excel repair tool for corrupted Excel spreadsheets. Program open, read and save data from damaged Excel files.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise:
1. Click the Microsoft Office Button Office button image, and then click Open.
2. In the Open dialog box, select the corrupted workbook that you want to open.
3. Click the arrow next to the Open button, and then click Open and Repair.
4. Do one of the following:
3. To recover as much of the workbook data as possible, click Repair.
(a) To recover as much of the workbook data as possible, click Repair.
(b) To extract values and formulas from the workbook when an attempt to repair the workbook is not successful, click Extract Data.
Oct 17, 2015 | Computers & Internet
Winrar repair corrupted .Rar Files
Sounds like the rar file you got is corrupt.try downloading it again.
Mar 03, 2015 | RARLAB WinRAR
Office word files in my pc become corrupted. I can't read them.
Try to repair your corrupt file with the help of Open & repair. You can do this by following below steps:
Start->File->Open->Select the corrupt file->Click arrow next to open button->select open & repair
If you are still facing the same problem then try to start MS word in safe mode.
If you will be able to open the file in safe mode then there is a problem with add-ins. Delete all the add-ins to fix the problem.
Nov 02, 2012 | Microsoft Office Word 2003 for PC
My excel 2010 file .xlsx was damaged or corrupted. how can i repair and getback
Use in-build "open and repair"utility of MS excel to repair damaged .xlsx files. Follow thesesteps to it
  1. On the File menu, click Open.
  2. In the Open dialog box, select the file you want to open, and click the arrow next to the Open button.
  3. Click Open and Repair, and then choose which method you want to use to recover your workbook.
Most probably your problem may get fixsuppose due to any reason it can't fix your problem then use thirdparty excel repair softwarehttp://www.stellarinfo.com/excel-recovery.htm
Dec 20, 2010 | Computers & Internet
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Microsoft excel file crrupted
To open a corrupt file; you have to repair the file first.
MS Excel has a special feature to repair corrupt file that is Open & Repair.
Repair a corrupt excel file by following steps:
  • Open a blank wordbook.
  • Go-to the File menu and click on the open button.
  • Now select your corrupt file and click on the arrow next to open button.
  • Select Open & repair option and click on the open button.
  • Save as the file and give the new name.
Additionally you can try 3rd party excel repair software if Open & Repair fails to repair corrupt file.
Sep 13, 2007 | Microsoft Office Standard for PC
Televison & Video Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
