Question about Vehicle Parts & Accessories
1990 ford f 350 dc desiel starts then stops - Vehicle Parts & Accessories
    Genius:
  • Vehicle Part... Master
  • 2,494 Answers
Check the fuel cut off solenoid on pump,check fuel pump and filter.
Posted on Aug 10, 2014
Why 1989 ford econoline 350 motorhome has 2 batteries
Typically if the batteries are in the engine compartment they are for the engine. There are usually a bank of remote batteries located in an access panel in the R/V body.
May 08, 2016 | Ford Cars & Trucks
2005 f350 6.0 desiel wont crank. found broken clutch switch, replaced it still wont crank
Check for blown fuse under dash and under hood , make sure new switch is adjusted to the clutch pedal ,make sure the connecter to new switch is not damaged .
Mar 04, 2015 | 2005 Ford F 350 Super Duty
90 ford f-350 headlights and overdrive doesn't turn off and rpm guage stopped working,this everything happened same time,what it can be,i think may be its pcm,is anybody know about this problem?
Yes--the main computer is a possible culprit. You can really tell if the symptoms change from one time you start the vehicle to the next. e.g.-black smoke out the tail pipe.
I had a computer problem once--I unplugged the water temp sensor and drove it--after a quarter mile it died and would not start. Weird things were happening like when driving at a steady speed there would be hesitations as if I were playing with the accelerator.
I hope this helps.
Nov 09, 2013 | 1990 Ford F350
Have 2006 f350 desiel. driving home and check engine light came on. Went out next morning and truck wont start.
Fuel pressure good battery is good make sure the positive part of the batery post has good connection, a good indication of hard to start is glowplug relay you should hear the clicking of that relay when you turn the key on. The FICA has alot of problems with no start and so does the ICP. You need the scan tool data stream to track this down for a no start.
Feb 28, 2012 | 2006 Ford F 350 Super Duty
F350 2006 desiel 6.0l oil has all gone into the into cooling system
on the side of the engine under the exhaust manifole is a heat exchanger, coolant and oild flow through it, first to heat the oil then to cool it, that is where the leak will be found
Apr 15, 2011 | 2006 Ford F 350 Super Duty
On my friend's f-350 desiel 1991 .the colder it gets the harder the engine is to start could give me a clue. thank you.
it might need the fuel cut to 70/30 depending where you live i mean 70 percent diesel and 30 percent kerosene,but glow plugs are always a good idea to replace when these things start to happen,they do burn out.
Nov 24, 2010 | 1991 Ford F350
2003 f-350 cuts out , spitter sputter while driving
Just heads up we have a 2003 ford f 350 super duty desiel 6.0litre... There are many many problems with this truck.The jerking is just one of them and does get worse have taken to ford and they cannnot determine why... Do some research on the computer about the problems that many are having with this tryck that i have mentioned above..... THEY ARE ALL TRUE, UNFORTUNATELY.... If you have this same truck....
Dec 09, 2008 | 2002 Ford F350 Super Duty DRW Reg. Cab
95 ford e-350 powerstroke desiel engine
if you heart a clicking sound from the solonnoid you netural safty switch is ok. i would take off the starter and take it in to have tested
Aug 23, 2008 | 2007 Ford E-350 Super Duty Length XLT
F-350 chassis - Motor Home
Ford reccommends Type F,but in my opinion,Type F or Mercon varnishes quickly.I've been rebuilding Ford's auto's for 19 years,and have found Dexron 2 or 3 works just dandy.Mixing the two fluids won't harm anything.The biggest thing is DO NOT use any kind of trans stop leak which contains brake fluid.
Jun 30, 2008 | 1990 Ford F350
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
