Question about Kenmore 72073 Top Freezer Refrigerator
How do I defrost kenmore 106.71182101
Don't see a hose to let water out?and don't see and off dial
2 Suggested Answers
  • 218 Answers
SOURCE: not making ice
The kink in the hose should not have caused anything to burn out. There are no pumps in the fridge - normal water pressure is sufficient.
There's a pair of solenoid valves in the back - one for the icemaker and one for the water dispenser. They operate independently but are usually built into a single assembly. If the electro-magnetic coil is burned open on one or both of them, then you need to replace the valve assembly.
Another possibility is frozen water in the line.
Posted on Oct 14, 2008
Have kenmore carpet cleaner, upholsery tool don't, water will not come out the hose, what's wrong?
the hose has a memory crimp take it apart the handle that turnes the water is stuck closed all you need to do is squeese the hose to open it up and reasemble will work fine
May 22, 2012 | Vacuums
My upright freezer freezes everything fine my only pro.blem is that it builds up ice/frost on the ceiling of the freezer first and then works its way down i have taken everything out,started fresh and...
Since you didn't give a model number, I don't know if it is frost free or not. If it is, then you have a problem with you defrost system: defrost heater, thermostat or defrost timer.
It also sounds like your door seal is not making solid contact and most air is leaking into the freezer.
If your unit is a frost free, then water should drain down and out.
Jun 24, 2011 | Freezers
THE WATER DON'T COME OUT AND DON'Y MAKE ICE, AND THE WATER SUPPLIES IS OK
Good day,
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running through them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look okay the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
May 13, 2011 | Kenmore Side by Side Refrigerator
My Kenmore Elite side-by-side has had many issues over the years and you have always been able to answer my question, and I have always been able to repair it. NOW: ice is forming at the bottom of the...
You have a drain for the defrost water that is plugged. Once you have it defrosted you will see a drain trough and drain hole way in the back of the freezer. You can try blowing it out or maybe take a soft wire and try to clean it out. I have found that a piece of tubing from a fish tank works great. Of course I am asuming that you don't have water leaking from the ice maker. I'm sure you would have noticed that.Hope this helps.
Apr 29, 2011 | Kenmore 56983 Side by Side Refrigerator
Not making ice
Oct 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 19 frezer on bottom
  • possible causes:
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 72073 Top Freezer Refrigerator Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
