Question about ASUS Computers & Internet
I have a three weeks old AsusX551MA series, can you please help me because when I turn it on I can see the arrown on the screen but no picture or I can't start it.
    Top Expert:
  • ASUS Master
  • 14,161 Answers
Posted on Jun 18, 2015
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
The screen stays black. Yes, I have batteries, I do get instructions and images for video or camera, but I can no longer get a visual of anything the camera is aiming at. It's like there is a lens cap on...
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Mar 15, 2011 | Cameras
Calapsed picture frame
This can only be a bad soldered on the video module, its better to check for any bad soldered and for any fault on the resistor on the video output module.
Hope this initial info / idea helps.
Please Accept my solution if I solved the issue.
Regards,
micro
Mar 27, 2009 | Televison & Video
Flash Off
Not sure about your camera but most of them yes you can turn of the flash.
Its usually in the settings; just remove it from "automatic flash" to "no- Flash" its sometimes symboled like a lightning arrown downwards. Look around it will be in your settings.
I hope this helps, please don't forget to rate my solution.
Thanks
Mar 15, 2009 | Kodak EasyShare C310 Digital Camera
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Please, Help me fix my TV
It sound like you have abad picture tube. Iknow this is not the answer that you want to hear. Sony's have video blanking circuit built into the video processor(in the jungle IC) when the emission of all three gun fall out of an acceptaable range. the screen blinks and when you turn the screen control on the IHVT all you see is re-trace. Some times there is a current limiting resistor in series with on lead of the heater on the crt board. By changing this resistor from 2.2 ohm to >.1 ohm @1/2 watt you can sometimes increse the filament voltage to the point that the blanking stops. This is only a temporary cure not a fix. The picture tube is probably bad. Scrivitron
Jun 20, 2007 | Sony KV-20FS12 20" TV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Computers & Internet Logo
233 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
