Question about Radio Communications
Looking for a schematic diagram for a LEX Lighting DMX-512 controller
There is no output to lighting but all other controls work, suggesting possible fault on output chip. need a part number for this chip
  • 1153 Answers
SOURCE: Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Posted on Sep 09, 2007
  • 231 Answers
SOURCE: dash lights dont work
sounds like you probably just blew a fuse , check your fuses , there should be a diagram on the fuse pannel cover that tells you what each fuse is for.
Posted on Oct 09, 2008
nuwan chinth
  • 111 Answers
SOURCE: Schematics Required
hay guy,
i also need the diagrams.i tryed many way to find it.but it dosent work.
anyway im repairing efka & quick rotan by myself without any diagrams.
if you like i can share my knowledge with you.
email me .
first sms me .00940772532280
nuwan
Posted on Nov 26, 2008
SOURCE: Headlights cut out after being on 10 to 15 minutes
I had the same exact problem. I found that I could make the lights come on by pushing on the top connector on the front side of the lighting control module (LCM). I pulled the connector off, cleaned it and put it back together with some dielectric grease. Only time will tell if I fixed it. On my car, it would only have problems after the headlights had been on for about 3 hours; kind of hard to re-create.
Posted on Mar 24, 2009
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
I bought your fog machine ,there was no remote control in the box,how do I get one
what brand and model did you buy...Some come with a remote...some are DMX and are meant to be controlled by a light system board or controller or some type. These typically dont come with a remote....You can always buy a controller or a wireless dmx remote as well.
Oct 10, 2015 | Mbt The Fazer Pro Fog Machine Dj / Stage...
My running lights are working just fine no brake lights any suggestions? 1999 Lincoln continental
Brake light switch ? Lighting control module , fuse's ?
The stoplight switch is protected by Fuse 32 (15A). This fuse is hot at all times. With the stoplight switch closed, power is provided to the stoplamps through the lighting control module through Circuits 9 (LG/O) and 5 (O/LB). Ground is provided to the stoplamps through Circuit 57 (BK).
Symptom Chart-Stoplamps
Refer to the Electrical and Vacuum Troubleshooting Manual for connector numbers cited in the pinpoint tests. Use Rotunda 88 Digital Multimeter 105-R0053 or equivalent to perform pinpoint tests.
Symptom Chart-Stoplamps Condition Possible Source Action
  • No Communication With Lighting Control Module
  • Circuitry.
  • Lighting control module.
  • GO to Pinpoint Test BA .
  • Stoplamps Inoperative
  • Open fuse.
  • Circuitry.
You may want to take to a repair shop !
PINPOINT TEST BB: STOPLAMPS INOPERATIVE BB1 TEST STOPLAMPS
  • Press stoplight switch.
  • Check stoplamps and rear high mount lamp.
Are lamps on? Yes No RELEASE switch and make sure that lamps turn off. CHECK Fuse 32 (15A). REPLACE open fuse if open, RESTORE vehicle, RETEST. If fuse is good, GO to BB2 . BB2 TEST STOPLIGHT SWITCH INPUT
  • Connect Rotunda New Generation Star (NGS) Tester 007-00500 or equivalent to data link connector.
  • Enter diagnostic data link.
  • Enter lighting control module.
  • Enter PID/data monitor and record.
  • Select PID: BOO_LCM - Stoplight Switch Status.
  • Hold stoplight switch.
Does data display read ON? Yes No GO to BB5 . GO to BB3 . This is with a factory scan tool , a code reader will not work !
BB3 TEST FOR VOLTAGE AT STOPLIGHT SWITCH
  • Test for voltage at input Circuit 10 (LG/R) to stoplight switch connector C253 .
Is B+ present? Yes No GO to BB4 . SERVICE Circuit 10 (LG/R) feeding stoplight switch. RETEST system. BB4 TEST VOLTAGE OUTPUT AT STOPLIGHT SWITCH
  • Test for voltage at output Circuit 511 (LG) of switch connector C253 .
Is voltage B+ at the switch? Yes No SERVICE Circuit 511 (LG). RETEST system. REPLACE stoplight switch. RETEST system. BB5 TEST POWER TO LIGHTING CONTROL MODULE
  • Disconnect connector C207 from lighting control module.
  • Test for voltage at connector Pin C207 , Circuit 907 (Y/W) and Pin C207 , Circuit 906 (R/O).
Is voltage B+? Yes No GO to BB6 . SERVICE Circuits 906 (R/O) and/or 907 (Y/W). RETEST system. BB6 TEST OUTPUTS
  • Using jumper wires, short Pin C207 , Circuit 907 (Y/W) to Pin C207 , Circuit 9 (LG/O). Using jumper wires, short Pin C207 , Circuit 906 (R/O) to Pin C207 , Circuit 5 (O/LB).
Do stoplamps illuminate? Yes No REPLACE lighting control module. RETEST system. SERVICE Circuits 5 (O/LB) and 9 (LG/O) for open circuit or damaged bulbs. REPLACE open bulbs as necessary. RESTORE vehicle, RETEST. This is Lincoln factory service info !
Jul 04, 2015 | Lincoln Cars & Trucks
Chauvet Obey 70 service manual
They are not worth trying to fix, if you really like this unit you can get a secondhand one for about 25GBP or find one from a decent manufacturer or even better how about a USB interface to DMX for your PC?
Dec 18, 2013 | Chauvet Obey 70 Dmx-512 Light Controller...
How do i connect lights to a yamaha emx 512
There is no way to hook up any form of lights to the Yamaha EMX512S. If you want to use DMX lights, you would need to buy a DMX controller. There are both analog and software controllers. Controller prices can range from $50 to over $500.
Aug 24, 2011 | Yamaha Emx88s Powered PA Mixer System
I have an Elation FC400 DMX foot controller and an Eliminator ED15 Dimmer pack (8 plug ins). Cannot get controller to do anything when Dimmer Pack set to Slave mode, Dimmer pack works fine on Programs...
In slave mode the second pack should be controlled by the first pack in the chain, not the foot controller. I think you probably don't want to be using slave mode if you are using external controller... try setting the packs to the same address so they both track the foot controller.
Jul 27, 2011 | American DJ Dmx-16 Sw System 16 Ch Dmx...
D4dmx-md5 stop working. No schematic. Problem came slowly then it stop working. Get a bit of light on the led display Maybe a power supply problem
You did not post enough information on symptoms to get a good answer. However, the most common problem with these dimmer packs is a failure of the sermiconductor that controls the amount of power going out to the attached light. In the D4DMX, there are 4 such, of a type class of semiconductors known as "triac", part industry part BT16A (the "A" is important, as it indicates an internally insulated mounting/heatsink tab). When this part fails, the output channel stops working, but the other 3 channels continue to work. Altho rarer, it is possible for multiple channel triacs to fail. The failure of a triac is typically due to (1) attached bulb filament failure (in a manner where a filament fragment shorts across the mounting posts), (2) channel overload (eg, plugging in a greater load (significantly greater wattage) than the D4DMX channel is rated for), (3) AC power line surge. You need to be a trained & experienced ELECTRONICS (ie, NOT electrician) to accomplish this repair safely & satisfactorily, and it involves soldering & specialized test equipment.
The D4DMX series is also known for failures of its control cable interface circuitry, both for Microplex and DMX. Microplex failures is more common, as that type of interface is more sensitive to induced noise from nearby AC wiring, radio signals, and standing wave reflections from varying lengths of control cabling. DMX uses a differential control signal interface, which makes it much more immune to induced noise, but it operates at a lower signal voltage which makes it more sensitive to accidental application of improper voltages on the control cable...which often happens when someone connects the DMX ports on the dimmer pack to a Microplex connector on another pack or the control console. One clue is to look at the single tiny LED right next to the control cable connectors; if it's lit green, then the Microplex signal is detected, if it's lit red the DMX signal is detected, if it's not lit at all (off) then no signal is detected which just may be an interface circuit failure. Such problems are a bit more challenging to troubleshoot internally, and requires a proper oscilloscope or logic analyzer.
In both of the above cases, you will see what may look normal on the LED display, but the dimmer pack will not function properly.
You should describe more symptoms of your problem, such as: Are all light output channels not working, or just 1 or 2? Which control interface are your using (Microplex or DMX)? What is your LED display saying? What are the present settings programmed into your D4DMX? Are any other working channels responding to the control console normally? What is the total length your control cables, including those between serial connected ("daisy-chained") multiple D4DMX dimmer packs? Do you have any non-D4DMX dimmers in the control chain, and are they all connected using the same type of control interface (Microplex or DMX)?
May 23, 2011 | Leviton D4DMX-MD5 4-Channel Programmable...
Just got a Chauvet Trident and plugged it in and the moter tunrs left then right , then stops ? The LED's blink 1 time then that is it ?
The left right motion is when the motor calibrates its position. The unit is then waiting for input... try generating a loud noise... if the audio gain is up and it is configured for manual rather than DMX it should start.
Dec 24, 2010 | Chauvet Brand New Chauvet Trident Dmx-512...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
