Water will not drain after wash cycle - Washing Machines
  • 79 Answers
Take the drain hose from the pipe, and lower it to the floor. If it drains good, you may have a bad contact in the time, or a bad water pump, or belt, depending on the brand (you didn't specify). If it doesn't drain by lowering the hose to the floor, their is a item of clothing stuck somewhere between the tank outlet to the end od the hose. Check pump inlet 1st and pump.
Posted on Jun 24, 2009
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
