Question about Delphi Roady XT XM Radio Receiver
How to repair antenna connection on delphi roady
The copper cage on the bottom of my roady is missing. it had come loose and i need to repair for it to work i am wondering if there is any type of repair place or advise that will help in this problem
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 47 Answers
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
Posted on Jun 15, 2014
Testimonial: "the antenna connection on the radio itself"
  • Steven Fleming Jun 15, 2014
    can you post a photo of the affected area?
SOURCE: "Antenna" Appears on Roady XT Display
I had the same problem, it says antenna when you turn it on. It seems that there is a small wire that stays in the radio side of the socket right in the middle of the socket. This fine wire breaks off . I think there is no known repair for this. I took a piece of fine wire from a wire brush, and poked it into the socket . Had to get one that was thick enough to stay. Then I plugged the antenna into it, it worked.
Posted on Dec 18, 2007
SOURCE: Delphi Roady XT won't turn on
same deal here fuck delphi
Posted on Feb 19, 2008
SOURCE: Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Posted on May 08, 2008
dmftrucker
  • 1922 Answers
SOURCE: Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Posted on Nov 17, 2009
SOURCE: Delphi Roady xt, cassette adapter problem
I was thinking how can I trick the cassette into keeping the cassette in there because every time I put it in, it just came right back out
This is what I did
Go and find a real cassette and cut out a little piece of the cassette tape and set that aside
Every cassette is different so find a way to attach tape from a real cassette to the cassette part of the cassette adapter
You need to attach the tape so it is flat over the head of the cassette just like in a real cassette, which is the part where the music is transferred, once u get it over the head the cassette deck will think it is a real cassette and it will stay in the deck, the tape doesn't even need to be perfectly flat like in a real cassette tape, it can be all messed up and it will still work but flatter is probably better, so you are just tricking the deck into believing that it is a real cassette, it worked for me and hopefully it will work for you, tell me how it works out
Posted on Mar 10, 2010
I continually loose my reception on my xm roady xt, i wiggle it around and then it works again, and so on. do i have a bad base unit and do they wear out over time. mike@fgoh2o.com
You need to resolder your antenna port on the dock connector. It's a really easy repair, all you need is a fine tip soldering iron. The antenna jack is on the right of the dock connector, it has 1 middle pin and 1 n-shaped pin that leads to 2 pads on the PCB. Your middle pin most likely has a cracked joint.
Dec 28, 2010 | Delphi Roady XT XM Radio Receiver
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
'Antenna' message on Roady
Hi there check the back of the docking staion. The connection is LOOSE or try to make sure that you have not keep it in the sun for to long just let it cool down
Rate FixYa Expert Kindofcheap
Aug 30, 2008 | Delphi Roady SA10035 XM Radio Receiver
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Antenna connection
Check to see if the center pin in the antenna jack on the radio is bent or missing. I have a Roady II and that is the problem with mine. You may need a magnifing glass to see it.
Dec 06, 2006 | Delphi Roady SA10035 XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
251 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
