Question about Magellan Smart GPS
My N399M Smart GPS won't turn on?
Was working fine then one day just wouldn't turn on. Tried running it on a different power cord, nothing. Unit is about six months old. Has done a few strange things in six months, but nothing I haven't been able to figure out until now.
  • 38 Answers
SOURCE: Freezing with a blue or checkered screen
try holding the reset button on the back in for 30 seconds.    Sounds like its in test or programming mode.
Posted on Oct 25, 2007
montecarlo
  • 50 Answers
SOURCE: GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Posted on Jan 06, 2008
salt56
  • 373 Answers
SOURCE: No Power
If you have an volt meter, do check for 12volts DC . Otherwise the GPS unit is defective and highly technical
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: Battery
BertM, I had the same problem and also do not use it frequently enough. The unit finally gave way about 7-8 months. I am hoping that Magellan will honor their warranty and find it's bad battery. I am awaiting an RMA. Visit following site for help:
http://www.magellangps.com/support/askmaggie.asp
Posted on Jun 30, 2008
SOURCE: power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Posted on Aug 11, 2008
Cornea 47" Flatscreen won't power on, red standby light lit
Could be power supply failure. Capacitors can be defective without visible indications.
Jun 07, 2017 | pcb Televison & Video
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
Wont power up
The nuvi 200W is an older unit and it may be possible that the battery has run it's life out.
The average life span of a GPS battery is 2-3 years and possibly a bit longer depending on different factors such as climatic conditions, amount of usage, etc.
Nov 23, 2011 | Garmin nuvi 200W GPS Receiver
My Keurig will not turn on...no lights flashing, nothing...I used it two days ago and it was fine...i came back into work and it wouldn't do anything. I tried unplugging it and leaving it unplugged and...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
I plug it in and there is no power to the unit. The green light on the cord lights up, but the unit does not turn on. I tried the reset button - didn't do anything. Ideas?
I had a similar problem. I think (not 100% certain) that there is a "break" somewhere in the power cable and have found that if I bend the power cord into different positions it eventually gets power to the unit. Not the most sophisticated solution but best I can do.
Jul 18, 2009 | Navigon 2100 Max Portable GPS System
Garmin GPS will not work
tape holds strip cable down, could have got hot in window and loosen the tape. pull front panel out, very carefully, 4 screws secure the unit, It will snap apart, so start looking inside ffor the brown tape in the rear protion of your GPS
Mar 21, 2009 | Garmin StreetPilot c530 GPS Receiver
My street pilot c330 wont power up
I am continually amazed by how many people list there problems with only the barest of explanation. How on earth do you expect a reasonably informative answer when your total description of the problem is "my street pilot c330 wont power up"? OK, so tell us more! Did it work just fine until one day it stopped? Did you let it sit for 6 months and when you plugged it in again... nothing? Did you check the fuse in the power cord? Oh, you didn't know there was a fuse there? Read the book! If you want help from me, kindly describe in a bit more detail just exactly what the problem is, a bit of history of what, if anything, led up to the problem, etc.!!!
Jan 27, 2009 | Garmin StreetPilot C330 GPS Receiver
GPS Maps 60 Won't turn on...
I had a similar problem. I opened the unit up and the two contacts (little metal tabs) that make contact from the battery to the circuit board had to be bent up a bit so they make contact.
Sep 09, 2007 | Garmin GPSMAP 60 GPS Receiver
Legend CX just died
Connect your unit to your PC. Even if it doesn't show connected, run the software update for your unit. That has been known to work in the past.
Jul 25, 2007 | Garmin eTrex GPS Receiver
Magellan Smart GPS Logo
117 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
