Question about Frigidaire Cooktops
Weight I would like to use a pressure cooker on my glass range top. Is there a weight limit for these tops? thanks
  • Frigidaire
    Frigidaire May 20, 2014
    Good Afternoon Friend, I understand that you want to use a pressure cooker on your Frigidaire glass range-top, and are wondering if there is a weight limit for the glass-top. I will be more than happy to assist you. If I could please have the model number of your range, this way I can better assist in answering your question. You will be able to find the model number either on the back of the door or in the bottom drawer, if there is one. Looking forward to hearing from you. WP
jtbjtb
  • 135 Answers
SOURCE: Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Posted on Jan 01, 2009
garing
  • 998 Answers
SOURCE: crack in glass flat top jenn air range
big job... too much money
Posted on Aug 08, 2009
  • 222 Answers
SOURCE: I have kenmore ceramic top range model number
are u sure u want to replace the ceramic glass top,much beter to check the price of the unit, coz it is very expensive almost halt the price of the new one...dont try to replace it by ur self coz the glass cover is no waranty if u broke or wrong intallation,u waste ur money if hapen that,much beter to canvas first & call an expert tecnician to do it.
Posted on Sep 13, 2009
  • 27 Answers
SOURCE: my glass top has a broken in the corner on my
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Posted on Apr 23, 2010
  • 1267 Answers
SOURCE: I need to replace the
It looks as if you need to remove the whole cook top to replace the glass top, incidently that is a 400 dollar item, so you have to take care. See: http://www.partselect.com/PartDetail.aspx?Inventory=2341162&SourceCode=5&ModelNum=jed8430#RepairStory
Posted on Apr 11, 2011
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
What kind of cookware is recommended for glass top stoves
Glass ones work best, but any heavy metal will also work. Heavy gauge not heavy weight. The lighter metal tends to bend and warp after a lot of use. If the bottom of the pans are not absolutely flat, these stoves will not heat the pan very well, which is why the glass cookware is the best to use, since it will not warp.
Feb 27, 2015 | Maytag 6.2 cu. ft. capacity electric range...
How do you remove a 318223634 glass top frididaire
Good Afternoon Leslie, this is Z. Thank you for your post!
I see you are looking for information on how to remove the glass-top of your Frigidaire Cook-top (318223634). It appears above-listed model number is invalid; however, this is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website. Best regards.
May 03, 2014 | Frigidaire Stove/Oven/Range Black Glass...
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
I need a replacement glass top for my Thermador CEP 365/CET365 cooktop. It is cracked but works fine. Where can I get this?
contact the service agent for the brand to see if a replacement glass is available
in reality you are not required to replace the glass as glass breaks in normal use and is out of your control and in renters terms comes under fair wear and tear
Dec 21, 2017 | Thermador 37 in. CEP365 Electric Cooktop
Less than a year ago we puchased our viking 4 gas burner top with black ceramic glass. Now, out of nowhere, there is a crack in the top. It could have been done by the maid but now I need to know if it...
Hello, welcome to FixYa.
The short answer is yes it can be repaired, however it requires replacing the glass top unfortunately...and as you may or may not know they are usually well in the range of $500-600 or more.
You can check on the availablilty of your particular cooktop at the link shown here or you may opt to contact a local service center.
http://www.allvikingparts.com/SearchResults.asp?Search=glass+top
Hope that at least answer's your question. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 07, 2011 | Viking 31 in. DGCU105 Gas Cooktop
I need to replace the glass top on a jenn air JES8850BCS slide in range. How do I do it? Can it be done leaving the range in place or does it need to slide out for the replacement? Thanks.
Apr 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
I have kenmore ceramic top range model number 79096011407, the glass top is cracked and I want to replace it but don't know how it comes off the manual is lost. There are three screws above where the oven...
Sep 08, 2009 | Cooktops
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Cooktops Logo
60 people viewed this question
Top Frigidaire Cooktops Experts
Oloyede Monsuru
ray gallant
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
