How can i hook up my smartphone threw my Motorola dch6200?
I have a Motorola DCH6200 HDMI cable box and would like to know how I can use it? Can you give me any advice as to what a can possibly do to connect my smart phone and use it to view movies on my tv and listen to audio?
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
SOURCE: onkyo reciever (R550) and comcast cable box won't talk to each other
Having the same problem, Please help.
Posted on Apr 23, 2008
DickCanFixIt
  • 948 Answers
SOURCE: How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Posted on Jan 01, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
mlapres
  • 757 Answers
SOURCE: Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Posted on Jun 18, 2009
Fix ref code s0600
Contact Charter support or contact Arris. ARRIS
Mark
Motorola Support
Aug 12, 2014 | Motorola Dch6200 Catv Digital Receiver
Ids manuals
Contact Arris
ARRIS
Mark
Motorola Support
Jun 20, 2014 | Arris Dch6200 Hd Receiver W/ Power Cord...
Set motorola dch6200 remote control
You're probably better off programming the cable box remote to control your TV. Samsung codes are standardized, Motorola not so much.
Dec 30, 2013 | Televison & Video
I have a new Samsung smart tv and I'm trying to set up the universal remote setup feature with my Motorola DCH6200 Set-top box. It doesn't seem to recognize my set-top box model number
Find the manufacturers website for the universal remote and download the codes for samsung smart tv, probably will be able to find a general code in the online manual of the remote.
Shaw cable ref code:S0a00 ,what does it mean
Your Shaw Digital Terminal (or PVR) is not authorized to receive that specific channel -- you need to call Shaw to "subscribe" to that channel.
Apr 19, 2013 | Motorola Dch6200 Catv Digital Receiver
Is there a way to factory reset (put in hunt mode) a Motorola DCH6200 without contacting cable provider and having them do it?
using your remote hit replay-list-live tv 3 times each it will shut of reset then press list and it will read 0
Mar 07, 2011 | Televison & Video
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
15 people viewed this question
 Grubhead
Grubhead
