Question about Canon PIXMA MP240 All-In-One InkJet Printer
Why canon mp258 orange light contineous blink?
judesoul
  • 127 Answers
SOURCE: canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Posted on Feb 07, 2009
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
pineworks
  • 4041 Answers
SOURCE: canon S600 orange blinking light 3 times. Error
How To Reset Waste Ink Canon Pixma MP450
It could be so gave it a go
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
SOURCE: my canon pixma mp258, the
I have this problem too...I can see is my ink inside the ink hose is stuck.....can't go in to the ink Cartridge....so that means problem is the ink ...stuck in the middle of the ink hose...if anyone how to run the ink in the ink hose...please help me..=]
Posted on Nov 01, 2010
SOURCE: canon ip1800 5 orange flashes then goes green,
The FINE cartridge cannot be
recognized.
Possible causes are as follows:
• The FINE Cartridge may not be installed properly.
• The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output
is not satisfactory, carry out the Print Head Alignment.
Posted on Mar 03, 2011
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer canon mp258 scane problem error code 2,140,2 give me solution
  • kishor kumbharePrinter canon mp258 scane problem error code 2,140,2
    May 05, 2013
    May 05, 2013
Jan 01, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Error code p08 showing. pixma mp258
This is a waste ink absorber warning. 3 choices 1. take to service center to have it cleaned, 2. attempt to clean it yourself, or what I did without problems on my MP470, 3. follow these instructions:
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Dec 28, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have canon mp 258 with error e27 how would i resolve it?
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jul 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Blinking
press the orange light of the printer for about 10-15 seconds. Print a sample. If your cartridge is refilled for about 3 to 5 times. Better buy a new one then modify it to continous one, this is to save you money from refilling again and again and also for good print quality.
Apr 04, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
19 people viewed this question
old marine
old marine
