Why won't lowry tv switch on?
Why does my Lowry tv keep turning off when I switch it on? I sometimes have to try seven or eight times ..
5 Suggested Answers
  • 108 Answers
SOURCE: Samsung HLM507WX/XAA getting hard to turn on
Replace the lamp.
Posted on Jan 08, 2009
westytech
  • 120 Answers
SOURCE: My HDTV keeps turning itself off, and is random if
It sounds like there is a component on the power board that is going bad. What I would recommend to do first of all is to do a factory reset, you can do this by going on to the menu, go under the settings tab, and it wil be the last option which is the factory reset. If this does not work you will need to replace the power board. You can contact Westinghouse parts department at parts@wde.com.
Posted on Jan 22, 2010
SuperTech-11
  • 1591 Answers
SOURCE: LC SK24u won't power on. rdlowry@lowry-law.com
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 14, 2011
  • 1156 Answers
SOURCE: hello am just wondering if
The power supply board is dead,Do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck and do take care in handling the television at the point of opening the back cover, because it is fragile and contain high voltage
Posted on May 13, 2011
My Lowry TV when switching on keeps shutting it's self off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2017 | Televison & Video
Why would our Lowry TV take numerous attempts to turn on?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 11, 2015 | Televison & Video
Lowry tv
Make sure the speakers are not turned off in the menu first, AFTER you unplug the set for 30 sec. and do a full reset.
May 02, 2014 | Televison & Video
To tune lowry dob radio model nogsdab1001
Lowry Dob or DAB radio???
If the latter, you don't have to tune it at all, DAB is a Digital Audio Broadcast radio and when you first plug it in you should find a button somewhere with setup or search on it, press this and Voila, you have magic happen.
Try it, it's great.
I hope this helps and by the way it's not a CB/2-way radio if it's DAB.
Cheers,
Peter
Feb 21, 2013 | Radio Communications
LOWRY TV
If using a box of some sort for signal remove it and the TV from power for several minutes and then hook back. I have seen on several occasions a box used cause this. Easy to do and may help.
Dec 21, 2012 | Televison & Video
Kindle fire picture freezes on a lowry pic
its processing 2 commands ,check settings
Nov 01, 2012 | Amazon Kindle Fire HD
Got a lowry tv an bought a new remote no instructions in box for code and how to set it to tv eny help please
had same problem and googled it han found codes to reset my remote. might try that. Good luck
Aug 12, 2012 | LeapFrog Televison & Video
Why doesnt the lowry freeview box have itv channel 4 or 5 whats the point of selling it?
Are you in a poor signal aera? The Lowry box is shockingly bad at picking up low signals. <br /> <br /> I had lots of problems with it, including a missing/intermittant itv channel.<br /> <br /> I swapped mine for a phillips
Feb 13, 2010 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
