Question about Dell Computers & Internet
Sony crt monitors gdm - Dell Computers & Internet
Tip
One thing you left out - this only applies to CRT monitors, LCD's are completely...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 11, 2009 | Sony SDM-HS73P 17" LCD Monitor
Pop - bang noise then went dead after a period of time
You've blown a capacitor and probably the horizontal output circuity. It's time to get a new LCD monitor.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
Blank screen - appears to be dead
If the screen is completely black, your screen may indeed be dead. There are a few solutions you can try before throwing in the towel though.
1) Test the monitor on another PC if you can.
2) Make sure the contrast, and brightness aren't turned all the way down.
3) Make sure the graphics card in your PC is functional. You can easily test this by connecting a known working monitor to your computer.
If these steps do not resolve the issue, and your graphics card is in good working order, you indeed have a dead monitor on your hands. It may be cheaper to buy a new monitor, than to have that one serviced.
Screen image on GPS 400 PS jiggles
Make sure that the driver is updated. Then if it is, contact apple.
Feb 08, 2009 | Sony GDM-400PS 19" CRT Monitor
Sony 24'' CRT widescreen GDM-FW900 blurry after initial on
CRT shorts are common with this model and focus problems are a major symptom. however, the loud 'pop' you described leads me to believe that the flyback transformer may have a problem in the focus divider portion. replace the flyback, if that fails then the CRT is most certainly the problem
Nov 20, 2008 | Sony GDM-W900 24" CRT Monitor
Display is off gray scale
I found it. I engaged expert mode in the OSD menu
Jul 31, 2008 | Sony GDM-90W11 24 in.CRT Conventional...
Screen always bleu
ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Jan 20, 2008 | Sony GDM-400PS 19" CRT Monitor
Monitor wont turn on
Check with another monitor, you will know where the fault is then.
Apr 02, 2017 | Sony GDM-400PS 19" CRT Monitor
Computers & Internet Logo
69 people viewed this question
Alun Cox
