Question about Health & Beauty
Why has my leg function deteriorated? - Health & Beauty
Can I put my arctic king freezer outside
you can but with extreme temperatures below zero or over 100 can cause erratic or proper function with unit as well as appliances exterior are designed to be inside will get deterioration to surface and hardware
Nov 25, 2016 | Heating & Cooling
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
How to attach kick stand spring on 2006 street glide
With the full weight of the motorcycle resting on the jiffy or side stand when it is placed in the full forward and down position it will lock into this position when the bike is leaned over the left side. If it is not in the fully down and forward position and on a flat/level and firm/solid surface when it is leaned over to the left side the bike may fall down.
To Remove the Jiffy Stand
WWAARRNNININGG
Block and support the motorcycle under frame to be sure that it is securely upright and level and so that the jiffy stand can be moved throughout its full range of travel and so that it will not fall down or onto the repair person when the jiffy stand is removed.
Then move the jiffy stand to the retracted i.e. up position and remove the ****** nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
To Install the Jiffy Stand
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the ****** nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
Sep 15, 2014 | Motorcycles
The mirror damper on my Canon AV-1 has been deteriorating (smashed). Are those dampers truly essential to the camera's proper function?
Basically, yes. The function of this foam is to both prevent mirror slap and reduce vibration, as well as to protect the mirror. The foam is easy, and cheap to replace, mirrors are not. Spend the $5 for the foam and not the $100 for a broken mirror.
Aug 05, 2011 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
How do you replace a Harley Road King kickstand spring
WWAARRNNININGG
Then move the jiffy stand to the retracted i.e. up position and remove the flange nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the flange nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
CAUTION
Jun 03, 2011 | 2006 Harley Davidson FLHRCI Road King...
My radio got wet it was working for a few days off and on and now it doesn't work at all but the face this come up
Most likely the radio is non functional at this point. Once circuit boards get wet even though they dry out and begin to work the corrosive effect that the chemicals and makeup of water continues a slow deterioration of them until they no longer function. Some components on a circuit board are extremely sensitive and this deterioration is like rust slowly creeping across copper circuit traces until current and signals can no longer move along them. Sorry for the bad news.
Oct 08, 2010 | 1997 Audi A8
Compressor has been not starting at times now wont start is it a cap or bad compressor
Could possibly be either. If you have access to multimeter with the capacitor check function you can test it or look at the capacitor. Sometimes they look like they have expanded when they go bad. You can also ohm the compressor windings to see if they are good. I don't know exactly what the resistance will be but it should be more than 0 and less than 100 ohms. Connect 1 lead of the meter to the common leg then check the run leg and then the start leg. Let me know what you find.
May 02, 2010 | Goodman CLQ36AR49 Air Conditioner
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Mot has me puzzled
just the four bushes or six including roll bar.
May 17, 2009 | 2002 Land Rover Freelander
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
