Question about Hayden-Harnett 1997-2001 Honda CRV Engine Cooling Fan Hayden 97-01 Honda Engine Cooling Fan 1998 2000
1998 Honda CRV P0505
Getting a diagnostic code of P0505 The check engine light is one seems ok unless I go higher than 45 mph...then I get erratic engine sounds like jerking at 55
2003 CRV Engine Light Code 1457 keeps coming back on after delete
If the code is back that problem that the PCM detected is still ongoing. Please watch the Youtube video at the link.
Honda CRV Code P1457 Honda CRV EVAP Solenoid
May 22, 2016 | 2003 Honda CR-V
Where can I find the diagnostic port for honda crv 1997?
THE 97 HONDA CRV DIAGNOSTIC HOOKUP IS UNDER LOWER CENTER CONSOLE,UNDER PLASTIC COVER,RIGHT SIDE CENTER.IT'S LIKE AN INCH OR TWO OFF THE FLOOR.I HAVE SAME VEHICLE.
Jul 01, 2014 | 1997 Honda CR-V
Where is diagnostic plug on 1998 crv
the obd2 plug of HONDA CRV is below the steering wheel. please check. any other questions, you can feel free to contact the tech support 2013 Multi Diag
Sep 10, 2013 | Hayden-Harnett 1997-2001 Honda CRV Engine...
The s light comes on and car will not start while it is on
"S" usually refers to the speed sensor This sensor translates your MPH and RPM . If the tranny is behaving erratically, try to troubleshoot by pulling the codes from the on board diagnostic unit (You can usually do this with a paper clip after you locate where the connector is located). Refer to Honda codes for your model They will blink on your dashboard and you count the number of blinks that correspond to the Honda engine code. the "S" light is sort of like the check engine light, except it refers to tranny problems only....there is a cable speed sensor cable, that is attached to the top of your tranny and runs to the back of the odometer.
Feb 16, 2013 | 1991 Honda Accord
1993 Ford Tauras engine light comes on intermdently @ 45 mph then goes off . What to do for smogging?
that is the code for your down stream o2 sensor . you need to replace that
Nov 12, 2012 | 1993 Ford Taurus
2001 CRV will not restart after sitting a few mintues
Have you had the engine control computer scanned for fault codes that might explain what this is? Do that first. You will need to buy a code reader for a OBD2 electronic engine control system, the diagnostic connector is in front of the driver under the dash.
Mar 18, 2012 | 2001 Honda CR-V
1998 honda crv, engine dies while running. after getting safely to the side. It usually starts back up and is fine. No missing or anything. It either works or it doesnt. I'm tinking fuel, but...
If you have a check engine light get the code. It may not tell you exactly the problem but it will give you a direction to look at. Where I live many auto parts stores will give you the codes for free.
Aug 13, 2017 | 1998 Honda CR-V
98 honda crv has p0505 code, engine shakes, no power.
Get a can of carburetor cleaner and spray it into the throttle body while the car is running.
Oct 28, 2009 | 1998 Honda CR-V
My 2002 Odyssey has an erratic idle and a P0505 trouble code
HI THIS IS Common cause of surging idle and the code P0505 is a sticking Idle Air Control (IAC) valve. Refer to Honda TSB #04-007 for updated part number. Hope this helps replace your IAC.
Sep 30, 2009 | Honda Odyssey Cars & Trucks
1998 honda crv misfire code 0303and 0304
problem solved mechanic had wires on wrong thanks
Nov 15, 2008 | 1999 Honda CR-V
Hayden-Harnett 1997-2001 Honda CRV Engine Cooling Fan Hayden 97-01 Honda Engine Cooling Fan 1998 2000 Logo
29 people viewed this question
Top Hayden-Harnett Computers & Internet Experts
ray gallant
RSole
Are you a Hayden-Harnett Computer and Internet Expert? Answer questions, earn points and help others
