Question about Geovision GV-800-16 Video Capture
Have 16 cameras and it only show 4 - Geovision GV-800-16 Video Capture
IFORFOT ADMIN PASSWORD FOR MY "XVISION MODEL:16D" PROFESSIONAL 16 CAMERA (4 AUDIO) H264 DVR - PLEASE HELP
You need to be good to do it
http://www.xvisionconsulting.com/obiee/reset-admin-password/
Sep 28, 2015 | Home Security
How do you monitor only 2 channels at a time on a lorex securtiy system ?
that can't be happen because all CCTV system dvr or nvr just split into 1/4/9/16 camera
Jun 13, 2014 | Lorex Home Security
Have geovision gv-600, the video lost on 5 out of 10 cameras?
If you confirm this is the card and not the cameras, then you may have some bad ports. You may need a new card. It happened to me at a customer after a lightning strike. Although mine was 4 cameras (1-2-3-4). You can also verify that the cameras are activated on those channels. That would be the easy fix.
Apr 11, 2013 | Geovision GV-600-16 Digital Video Capture...
How do i get the viewfinder to show fullscreen. At the moment there are 2 black strips down each side in "iauto" mode. When i first had the camera it was fullscreen. Thank you.
The LCD screen on the Olympus SP-800uz camera is widescreen (16:9).
If you set the camera to take pictures in (4:3) ratio you het the black sides.
Solution:
Select a Widescreen Image Size (see the manual page 30) by selecting one of
the available Image Size settings 16:9 (L) (4288×2416) or 16:9 (S) (1920×1080).
Jun 12, 2011 | Olympus SP800UZ Digital Camera
Full screen not displayed when viewing shot and playback
You mean that the image you take and playback is in 4:3 ratio. The default settings is 4:3. However, if you want to take widescreen (16:9 full LCD) images, just change the Image Size setting in the menu to 16:9 L (4288x2416 pixels) or 16:9 S (1920x1080 pixels). See the user manual page 30.
Oct 23, 2010 | Olympus SP800UZ Digital Camera
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
How do I expand my Tv screen
If the physical size of your screen is 4:3 the only thing it can show is a compressed version. The screen is physically not able to show the true 16:9 version. The true 16:9 HD signal has been developed to show on a screen that is twice as wide as it is long or 16:9 ratio. Your screen is almost square or 4:3 ratio. I hope this helps. Thanks for using fixya.
Dec 13, 2009 | Philips Televison & Video
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
AUTO VIVITAR LENS 135 mm 1 2 8 No 105870
Take the lens to a good camera shop and ask them what the mount is. They will be able to tell you what, if any, modern cameras it will fit on.
Oct 19, 2007 | Cameras
SmartMedia™ cards size
The D-400/450/460 and 490 Zoom can use a 2, 4, 8, 16 and 32 MB SmartMedia card. In addition, the D-450/460/490 Zoom can also use 64mb SmartMedia cards.
Aug 31, 2005 | Olympus D-490 Zoom Digital Camera
Geovision GV-800-16 Video Capture Logo
46 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
U-Spy Store DBA Pro...
Level 1 Expert
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
