Question about GE JEM31 Microwave Oven
How to repair sharp r1470a stirrer cover - GE JEM31 Microwave Oven
Sharp sound bar buzzing
test this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Oct 03, 2012 | Kenmore Microwave Ovens
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
Looking for a carousel with the three roller wheels for our sharp r1470a microwave.
That's the "turntable support" part number is FROLPB017MRK0
(note the difference between ohs and zeros)
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Apr 25, 2010 | Sharp Microwave Ovens
Sparks in the interior while microwave is on. Sparks come from the right side where there is a "cardboard like" cover over an opening.
IF THIS COVER IS DIRTY IT WILL SPARK. IF CLEANING IT DOES NOT HELP IT MAYBE CRACKED OR THE STIRRER BLADE MAY BE OFF
Jan 13, 2010 | Sharp Microwave Ovens
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
My sharp r-1381 is shooting sparks out the top of it any do it your self fixes?
That model has a stirrer motor and blade in the ceiling above the waveguide cover.
Arcing can occur if there is grease or food particles on the front or back of the stirrer cover, on the blade or around the motor shaft.
You would need to remove the stirrer cover and inspect the parts, then use a damp cloth to wipe the parts clean.
We have a partial service manual for this model and have uploaded it to our site here to help you. You may also need to refer to this base manual.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
The best place to order Sharp parts is Tritronics.
Oct 14, 2008 | Microwave Ovens
Maytag MMV1153BAW
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Maytag MMV1153A Microwave Oven
Maytag MMV1153BAW interior access panel
May 05, 2008 | Sharp R-530BS Microwave Oven
Need stirrer cover for microwave
THAT MUST BE A GOOD MICROWAVE. I'M SO SORRY I COULD HAVE GIVEN YOU MY MICROWAVE.I JUST TRASH MINE IT WAS A WHIRLPOOL TOO BUT IT WAS A 2002 WELL TRY HHGREG GOOD LUCK!!!!!!!!!!!!!!
Jul 14, 2007 | Whirlpool GT4185SK Microwave Oven
GE JEM31 Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
