Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
What can I do to get my dishes clean? They seem to have a film. I have a Viking 24 in Prof. serieis VUD141
  • 205 Answers
SOURCE: viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Posted on Jul 21, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking VUD141 advances through the cycles but won't drain water
The unit should be installed with a high loop in the drain line at the rear of the unit. If this is not in place it can cause the drain water to run back into the unit. If there is a partial blockage it could result in incomplete drain. Try disconnecting the drain line below the sink and run the unit to drain into a bucket see how it drains. would be a sign as to how free your drain line is.
It could also have defective drain pump
Posted on Mar 04, 2009
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
GodBlessU
  • 3513 Answers
SOURCE: I am looking for a
Hi
Please check the bellow link for the manual …
http://kitchen.manualsonline.com/manuals/mfg/viking/viking_dishwasher_product_list.html
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
  • 15 Answers
SOURCE: I need a power supply for a Viking 24 in.
any appliance store/shop can sell a power cord for your unit. the water hooks up front but you'll need an original water supply line due to the shape and fitting.
Posted on Jan 26, 2011
Hello -- I am having issue with this dishwasher! Water pools at the bottom and dishes are not getting clean!!!
Your pump is worn out. Time to get it to a repair man or get the manual out and if you feel handy be ready for some major expense and time.
Feb 14, 2011 | Viking 24 in. Professional Series VUD141...
I need a power supply for a Viking 24 in. Professional Series VUD141 and where does the water hook up at on the unit? Where can I get the Power Cord for this?
Jan 22, 2011 | Viking 24 in. Professional Series VUD141...
Not cleaning dishes well ant more. how can i fix it?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Viking 24 in. Professional Series VUD141...
How to instaal viking detergent dispenser
remove kick plate, bottom access panel, door panel and door latch (careful with the wiring) and than remove the 6 screws and 2 brackets holding soap dish.
Dishes/cups are not being completely cleaned. there is grit in the cups on the top rack, along with coffee stains still in the coffee cups. i sometimes pre-rinse, however, i didn't have to w/ my previous...
1)check the enough inlet water pressure. 2)check any block in the rinse nozzle. 3)check it attains the temperature. 4)check proper detergent& sanitizer going.
Jun 03, 2010 | Viking 24 in. Professional Series VUD141...
How do I find the door lock and a door seal (bottom of door) for my Viking VUD141 ?
Don't know about the lock, but the bottom seal for the VUD141 is part # PD100091 (just had mine replaced).
Mar 20, 2010 | Viking 24 in. Professional Series VUD141...
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Jan 10, 2009 | Viking 24 in. Professional Series VUD141...
Viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Dec 09, 2007 | Viking 24 in. Professional Series VUD141...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
46 people viewed this question
Top Viking Dishwashers Experts
Mike
ray gallant
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
