Question about Singer facilita 9858 Mechanical Sewing Machine
Bobbin for a facilita - Singer facilita 9858 Mechanical Sewing Machine
The bobbin thread doesn't hook with the upper thread, the bobbin disk doesn't turn as the band does
it would be a good idea to have the machine checked, to see if there is a loose or broken part inside the machine.
Mar 26, 2015 | Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
Bobbin case
Suggest you search in utube videos which be much easier for you to watch and understand.
Oct 30, 2013 | Singer facilita 9858 Mechanical Sewing...
Where can I find a zipper foot to fit my singer facilita 9858 and if it has a number what is it?
go to these websites and email them about the part you need
a1sewingmachines.com
sewvacdoctor.com
or contact a singer dealer
Oct 24, 2013 | Singer facilita 9858 Mechanical Sewing...
Como cosyirs repueto
I do not understand, What are you asking? I do not understand Cosyirs Repueto?
Apr 12, 2013 | Singer facilita 9858 Mechanical Sewing...
I have a Singer Facilita that was bought in the late 70's where can I get an instruction manual
Hi
I think you can get a free manual from the Singer site for this machine.
http://www.singerco.com/accessories/manuals.html
Just type in the model number not the model name e.g 288 and click on search.
Choose the second option from the list by clicking on free download!
You will see that this manual is the same for a number of model numbers.
Hope it's the right one for you!
Nov 25, 2010 | Singer facilita 9858 Mechanical Sewing...
MY TOP THREAD KEPT BREAKING AND NOW IT WONT PICK UP MY BOBBIN THREAD. I REPLACED THE BOBBIN AND PUT IN A NEW NEEDLE AND IT STILL WONT WORK.
try rethreading the top thread
and check the tension try 3-5
sometimes the needle & thread are not compatable-try this & see if it helps
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 25, 2010 | Singer facilita 9858 Mechanical Sewing...
Skips stitches when sewing
First change your needle, next check threading ti make sure it isn't wrong,
If these don't fix the problem then your timing is slightly off and needs to be set.
Aug 24, 2010 | Singer facilita 9858 Mechanical Sewing...
Singer facilita 9858 Mechanical Sewing Machine Logo
23 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
