Question about Poulan Pro 8" 25cc Gas Pole Saw PP258TP
Poulan Pro PP258TP fuel mixture - Poulan Pro 8" 25cc Gas Pole Saw PP258TP
    Master:
  • Poulan Master
  • 645 Answers
The manual calls for 40:1 but with the new "FD" rated oils it can operate on 50:1 ratio. I recommend using the pre-packed fuels. They have the "FD" rated oil and 93 -95 octane non-ethanol fuel.
Posted on Dec 12, 2017
  • 67 Answers
SOURCE: Fuel Mixture for a Poulan Wild Thing
as far as i know it is 1:40, or 3.2 ounce Oil to 1 Gallon unleaded regular fuel
Posted on Jun 06, 2009
wireguy212
  • 1627 Answers
SOURCE: What is the fuel mixture for my new Poulan Pro 18
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Posted on Dec 15, 2009
dontbother10
  • 2220 Answers
SOURCE: need baseline fuel adjusting mixture for 16 inch
I am not certain what you are asking, your manual says 1 gallon of premium fuel to 3.2 ounces of premium 2-cycle oil (40:1). If properly adjusted it will operate better on 1 gallon of premium fuel to 2.6 ounces of premium 2-cycle oil (50:1).
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine.
If asking about a needle valve adjustments an initial setting of 1.5 CCW from lightly seated then tuned as follows is a good starting point.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – not highlighted) files that I find most helpful, I think you will too.
This should answer both possible questions. HTH
Lou
Posted on Dec 19, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Jan 26, 2010
dontbother10
  • 2220 Answers
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Posted on Feb 19, 2010
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Engine dies when throttle engaged, assume carb needs adjusted, how to do that?
I'm not familiar with your brand of machine, BUT...
This symptom usually is not an indicator for a need for a carb "adjustment," but instead, it indicates a need to clean-out "gum" and "varnish" in the TINY passages [called "galleries"] inside your carb!!!!!
The gum and varnish problem is caused by leaving old, stale fuel in the carb for long periods of time.
May 22, 2014 | Poulan Pro PP258TP 12ft Gas Tree Pruner...
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
May 27, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
What type of fuel do I use in my push Poulan Pro lawn mower, reg. unleaded gas or mixture. I have been using mixture and mower is running sluggish. Want to know if I am using the right fuel.
If your mower is 2 cycle than there is a mixture, if it is 4cycle than there is no mix. Call your local repair shop and give them model number and they can assist you or call the place where you purchased the unit.. Good Luck....
Mar 11, 2011 | Poulan Garden
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine will not run when chock is not on
Hi
Try this link to find out where the carb adjusment screws are http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=401c0624-691d-43f6-9249-845e18527269&cat=3&TF=epcFrame&assem=452&highlightNode=No&selAssem=4447&mdDescrip=PP258TP Pole Pruner.
best regards savumihai71
Dec 17, 2008 | Garden
Poulan Pro 8" 25cc Gas Pole Saw PP258TP Logo
137 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
